E-Class (W211) 2003-2009
E550 (W211) Stock wheel specs?
Old Dec 20, 2007 | 10:15 PM
dauren85's Avatar
Question E550 (W211) Stock wheel specs?
Hi all,
I've searched and couldn't find the specs for stock E550 W211 wheels. I'm not sure what they're called. Can anybody help me out? Are they 17" or 18"? What's the width, offset and bolt pattern?
I'm talking about these wheels:
My neighbor has them and every time I look at them, I keep thinking that they would look good on my GTI with the right tires and drop if they're 18s
Old Dec 20, 2007 | 10:22 PM
SPNJHockey's Avatar
07 E350 4Matic / Sport with P1
from the owner's manual, page 484
Model E 350 4MATIC (Sport Package*)
E 550 4MATIC (Sport Package*)
Rims (light alloy) 8.5 J x 18
Wheel offset 1.5 in (38 mm)
All-season tires1
1 Radial-ply tires
245/40 R18 93V M+S
Get the entire pdf manual here:
http://www.mbusa.com/owners/vehicle_...ers_manual.jsp
And, if you have the staggered setup:
Model E 350 (Sport Package*)
E 550 (Sport Package*)
E 350 (AMG Sport Package*)
E 550 (AMG Sport Package*)
E 63 AMG
Front axle:
Rims (light alloy) 8.5 J x 18 -
AMG rims (light alloy) - 8.5 J x 18 H2
Wheel offset 1.18 in (30 mm) 1.5 in (38 mm)
Summer tires1
1 Radial-ply tires
- 245/40 ZR18
All-season tires1 245/40 R18 93V M+S -
Rear axle:
Rims (light alloy) 9 J x 18 -
AMG rims (light alloy) - 9 J x 18
Wheel offset 1.54 in (39 mm) 1.54 in (39 mm)
Old Dec 20, 2007 | 10:51 PM
dauren85's Avatar
Thanks for the quick response!
I got your PM as well, but still a little confused with all that info.
So to double-check, the wheels that I'm talking about are the non-AMG Sport Package wheels 18x8.5 -38mm, right? What's the bolt pattern?
If it's 5x112, then they will bolt right up and line up with the fenders pretty good i think...
Old Dec 20, 2007 | 11:54 PM
SPNJHockey's Avatar
That is the bolt pattern, wheel size and offset for the W211 w/sport pkg, but I'm not sure what it is - that you're trying to accomplish.
Old Dec 21, 2007 | 12:02 AM
dauren85's Avatar
Thanks, bro!
I drive a MK5 GTI (that W211 on the picture is not mine, I took the picture from the picture thread). I am trying to see if the W211 wheels will fit on my GTI, so I was asking for the specs. So it looks like they will fit perfectly onto my GTI.
Old Dec 21, 2007 | 12:05 AM
SPNJHockey's Avatar
OK, I re-read your original post: you wanna put those wheels on your GTI. The data offered by the W211 owner's manual tells you what MB recommends regarding wheels in relation to the W211. To find out if those wheels will be any good for your GTI, then you'll have to go to the GTI owner's manual to see what VW says your allowances will be.
Old Dec 21, 2007 | 12:07 AM
SPNJHockey's Avatar
Before you shell out big bucks for those rims, ck out:
http://www.tirerack.com/wheels/index.jsp
You won't be disappointed there.
Old Apr 24, 2015 | 12:34 PM
kpl's Avatar
kpl
2009 e550
Front and Rear 2009 E550 Tire Sizes
My E550 is ready for new tires. I know the rear are wider than the front and I had read somewhere a while back they required 2 different sets of tires for the front and back. Not being a mechanic can someone help me with what sizes I should buy for front and rear? Thanks! - Ken
Old Apr 24, 2015 | 01:58 PM
samaritrey's Avatar
Super Moderator
THE C350
Tirerack.com
You can also look at your current tires to get the size
