E-Class (W211) 2003-2009
Range function
Old Dec 28, 2007 | 07:13 PM
jyeh74's Avatar
Range function
Is the range function from the steering wheel an indication of how many miles I have left to go? It's weird cause it keeps increasing.
Old Dec 28, 2007 | 07:44 PM
ndasgruv's Avatar
95 s124 Estate, 69 911RS (tribute), 93 Toyota Pickup (DD)
I believe the range changes because it's dependent on you average MPG.
Old Dec 29, 2007 | 02:54 AM
Diesel Benz's Avatar
That's it, the computer would have to estimate the fuel consumption and it is using the recent average. If you drive less aggressively than before, your estimated range will increase. It also decreases faster than you gain miles if you do the opposite.
If you start and drive the same way constantly, the reading probably still improves a bit because of higher fuel consumption when first getting to speed.
Old Dec 29, 2007 | 04:13 AM
Taylor-Made'90's Avatar
'24 GLE53 AMG Coupe
The bottom line: DON'T TRUST IT.....
When the fuel pump light changes color, find a gas station.....
'Cause you're gunna look real stupid on the side of the road, pouring gas in the tank (after you've run out)......
Old Dec 29, 2007 | 04:56 AM
That probably is a good advice. Specifically if you don't know the distance to the next gas station or the traffic is very unpredictable. I often drive another 100 km after the reserve light comes on
It isn't that much what the indicated range is but the amount of diesel in the tank when the light comes on (guaranteed minimum 11 litres for me).
Old Dec 29, 2007 | 12:08 PM
lkchris's Avatar
'10 CL550, '12 GL550
The range function relates to how you're currently driving.
If you go from city driving to highway driving, your mpg increases and so does your remaining range.
Not rocket science.
Old Jan 2, 2008 | 04:19 PM
pinebaron's Avatar
07 E320 Bluetec
I often wanted to try it but usually fill up when there is at least a 1/4 tank full. It would have been different if my wife drove my car; she drives her SUV to its last few drops but she has never been stranded
Old Jan 2, 2008 | 04:36 PM
no_clue's Avatar
.... nothing to brag about, it is a previous model....
On flat surface when your fuel indicator light up, you should still have 3~4 Gallon reserve.
If your average city driving say...17MPG. You should still be able to get to your office 15 miles away and back home w/out problem.
Old Jan 2, 2008 | 10:08 PM
Barry45RPM's Avatar
2015 ML 350
Heh Heh... When it DOES happen, it will only happen one time to her... you can bet on that.
Old Jan 3, 2008 | 07:53 AM
Davel's Avatar
03 Eclass, 03 BMW 06 Porsche Cayman S, 03 Harley Davidson "bored & stroked"
You still have plenty of range once the low fuel light comes on, i've driven the car a few more miles when the range indicates ------- as in no more miles remaining. But there is no excuse for running out of fuel since you have the gauge, computer, and low fuel light warning you, but no need to stand on the side of the road, just call MB roadside assistance
Old Jan 3, 2008 | 11:47 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
FUEL TANK REMAINING menu will give you how many gallons are remaining in ur tank and how many miles u can go with it. very useful feature.
Old Jan 3, 2008 | 12:27 PM
Not any more in new cars. The mileage is there but not the gallons. At least on some cars it can be switched back on with service tools. Sounds like some IPR game again.
Old Jan 3, 2008 | 12:34 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
prolly just needs to be version coded...
