E-Class (W211) 2003-2009
Working temperature of Engine ?
Old Jan 13, 2008 | 06:31 AM
marios's Avatar
W211 E 270 CDI
What is normally working temperature of engine ?
I noticed when i drive my car that working temperature is 60C.
Is this working temperature TO LOW ?
Outside was +6C when this picture was taken and I was driving a car for 70km.
any idea? what it can be, because i dont want to be ripped of by a dealer.
Old Jan 13, 2008 | 10:26 AM
ohlord's Avatar
So
it was 43 f and the car was at 140f after 30-40 minutes of driving.The temp is to low,check that the coolant level is up to the line(mb fluid only or equal).Check that the fan is not stuck on.It could be a stuck thermostat or a faulty sensor,any cel on?If none of the above is is the case you can go to any good indie shop that works on a benz and they will locate the issue.
The gas engines operate in the 195 f range and is listed as 87C.Your manual should tell you the normal operating temp of the diesel engine or just call the dealer and ask what temp the thermostat is set for.If to low you really need to find the cause before it hurts the engine.
Still on warranty?
ohlord
Old Jan 13, 2008 | 10:45 AM
marios's Avatar
W211 E 270 CDI
coolant level is OK.
concentration is to -35 C.
the only thing what i suppose is Thermostat is not closing, and car is cooling too much.
Old Jan 13, 2008 | 10:46 AM
Diesel Benz's Avatar
It is way too low, check/replace your thermostat.
