Lowering questions...currently using H&R sport
Currently I'm lowered on H&R springs (-1.5F/-1.3R) with a staggered 18" wheel setup. Surprisingly my camber is in an acceptable range with these mods and without camber kits, front is at -1.38 and the rears are -1.25. Even with this lowering I still have a tire to fender gap of 1" in front and .75" in the rear on both sides.
The thing I don't understand is the reason why my car seems to have a more noticeable gap compared to people with H&R or Eibach springs with 18" wheels on our w211's. Is it because my Benz tech at Laguna Niguel re-used the original spring pads on the install? But from what I saw only the rear uses the spring pads while the front doesn't.
Or is there an alternative route that doesn't involve cutting springs (not acceptable) or maybe find some info that I cant seem to locate regarding aftermarket shocks that have a position to mount the spring 'lower' on the shock body.
Seahonu seems to be the only one running coilovers that is active on our W211 boards. I'm just want to make sure there is something else I can do to get that additional .5" lowering before I resort to ordering the PSS9's.
My 19's are supposed to arrive tomorrow and I really just want to reduce the noticeable gap on these larger wheels!
edit: I noticed I put the wrong info on the front camber, its -1.38 not -.38 as I previously posted.
I put the car back to stock because of tire wear. (lasting 5k miles for new sets only in the rear) After putting it back to stock, I still have the same issues with tire wear.
So I might just go through the whole process again and lower it.
