Cross Drilled Rotors
1) will E55 rotors work with my E500 calipers?
2) anyone know any aftermarket companies that are some what reasonable
and not $2,000 like the brembos.
3) How are the rotors on ebay? I see some really cheap ones on there.
One can treat the New UNUSED brake rotor via Cryo dip to help with wear/cracking of cross drilled brake rotors
Do your home work re the CHEAP EBAY Rotors...
See my thread on this:
https://mbworld.org/forums/showthrea...hlight=irotors
Of course it's your car and you're gonna do what you want, but if you're asking opinions, I will never put aftermarket rotors on any of my MBs ever again.
Regarding the other post about "Rotorpros", I would tread cautiously. This company (like many on Ebay) takes cheap OEM replacement spec non drilled/slotted rotors and proceeds to drill/slot them in a manner they were never engineered for. I once purchased a set for a C5 Corvette from this outfit; when I received tham I found so many visual flaws/issues that I never even installed them, just sent them right back for a refund. They were relatively inexpensive, but I quickly realized that you get what you (don't) pay for.
Unless you track your car, I would stick with MB parts for brakes, they will more than get the job done.
YOU will NEED THE AMG Brake calipers for the SL 65 rotors to clear and work
The SL65 uses a multipiece front rotor unlike the 55 that uses a one piece HEAVY front brake rotor
Price the SL 65 Rotors BEFORE you think of doing them...
