E-Class (W211) 2003-2009
E500 Headlights
Old Feb 12, 2008 | 05:22 PM
captrivers's Avatar
03 E500 Sport, 03 Eddie Bauer Explorer, 06 Pro Street Chopper
E500 Headlights
When I start the car and turn the headlights on in the manual position. The right or passenger side light lowers a few inches, then returns to it's correct height position. Is this normal? Do these lights move while driving? This model has the Xenon lights.
Old Feb 12, 2008 | 05:44 PM
konigstiger's Avatar
'71 Pinto
This is an auto-leveling feature at startup and while driving for the benefit of oncoming vehicles.
MBUSA introduced active Bi-Xenon (follow curve while driving) to the 211 in ’04.
Old Feb 12, 2008 | 06:03 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
If you have regular Bi Xenon lights both should move up and down on start up, that is the self leveling. Yes they do move while driving.
The active Bi Xenon will look up, down, left, right on start up.
Old Feb 13, 2008 | 09:40 AM
unclebenz's Avatar
I have a 03 E500 and it didnt come with the bixenon option so I bought oem xenon headlamps and had them put in, but my xenons dont move at all? how do I get it to auto level?
Old Feb 13, 2008 | 09:55 AM
captrivers's Avatar
OK, is there a test that I can run to find out if both are auto-leveling as intended. Like I said earlier when I first start it and manually turn the lights on. Only the passenger light drops a few inches. Then returns to the same height as the drivers side. The drivers side doesn't move during this.
Old Feb 13, 2008 | 01:52 PM
'71 Pinto
https://mbworld.org/forums/showpost....57&postcount=6
Old Feb 13, 2008 | 03:02 PM
E500Newbee's Avatar
2005 MB E500
Since everyone is on this subject. I do have a bi-xenon auto leveling lights which the lights do turn in the corner. But, can I manually adjust the headlights?
Old Feb 13, 2008 | 04:07 PM
'71 Pinto
Both should auto level. There may be a problem with a sensor or the harness, contact Sunil @ "MY WEBSITE" via link in post: https://mbworld.org/forums/showpost....83&postcount=6
Old Feb 13, 2008 | 04:16 PM
'71 Pinto
https://mbworld.org/forums/e-class-w211/35218-bi-xenon-headlight-adj.html
Old Feb 13, 2008 | 11:28 PM
E500Newbee's Avatar
2005 MB E500
wow...the thread is very old but it is very helpful...thanks Konigstiger
Old Feb 16, 2008 | 06:23 AM
captrivers's Avatar
Alright, the drivers head-light isn't auto-leveling. The day after I purchased the car it was raining and this light stopped working. I noticed it had an excessive amount of moisture in that housing. I thought the bulb went out. When I looked at it, the back cover was off. I removed the igniter and bulb. Cleaned the connection, put it back in and voila. It worked. Now I think I need to remove and clean the connections for the auto-leveling motor. Is there a way to get the entire housing out without removing the bumper? While I have it out I would like to clean the inside of the lense also.
Old Feb 16, 2008 | 05:01 PM
Abboushi's Avatar
911's and beyond
you have to remove the bumper to remove the housing its held by 3 10mm bolts 2 on top 1 on the bottom. to remove the bumper may take apx 1hour or so.Good luck
Old Feb 16, 2008 | 05:09 PM
captrivers's Avatar
I figured that, nothings easy anymore.lol
Old Feb 18, 2008 | 11:59 AM
Roehl's Avatar
2004 MB E-500 & 2000 Honda Accord Coupe
https://mbworld.org/forums/w211-amg/231016-bi-xenon-retrofit-50-pics-56k-no.html follow that DIY thread its awesome for taking out the bumper and headlight.
