How Bright is your headlight??
anyone have problem with it? please post some night time pics with it thank you!
Other areas to work on: This is generic information for any vehicle, though unusual on a newer car:
Check the battery ground wire and headlamp ground wire where it is secured to the vehicle. There may be minor corrosion (not easily noticeable). Remove, clean, lubricate with corrosion inhibitor spray and reinstall.
If you are not electrically challenged and have a voltmeter handy, you could measure the voltage across the headlamp bulb terminals with headlamps on and engine running; should be around 13.8V. Excercise the usual caution: watch out for engine moving parts, don't touch the bulb etc.
I have Xenon lights and they are the best headlights out there. I always can notice how much better my splash pattern is on the road when I am driving next to other cars.
Steve
A cheap option is to get a lens cleaning kit from an online source; includes rubbing compound etc.
I googled and found where you can get new lens though he will have them in a couple of weeks. $75 (each side)+ $12 shipping. Someone else viewing this thread may reveal other sources.
Rusty Cullens
BuyMBparts.com
1-800-741-5252
Steve
New lenses are the way I'd like to go. Do you know if you can change the lense without having to remove the assembly?
From start to finish I would say that it will take about 10 hours to replace the lenses.
How much of a difference would changing the bulbs make? Also, the inner, smaller lights..can they be "xenonized"?
