rp zinc
Our independent testing agrees with Comp Cams findings. Therefore, we are recommending either the use of SHELL ROTELLA oil with a 15w40 weight during the initial start up and during the break in period of your Blueprint engine. If you wish to use another brand of 15w40 oil, you must use a break-in additive such as Lucas Oil Break-in Additive (which also increases the zinc content). After the critical break in period, synthetic oils such as Royal Purple can be used. Alternate brands that have the CI4 service rating can also be used. "
Return to Tech Tips Main Page
I believe Delo 400 and Mobil Delvac are also high zinc content and heavy soot load rated. I run all of them (Rotella, Delvac, and Delo ) in my stuff but not the M-B
