E-Class (W211) 2003-2009
2005 E320 Headlight Adjustment
Old Feb 25, 2008 | 11:24 AM
bcarrjr's Avatar
2005 E320
My high beams point towards the heavens.....I looked to see where the adjustsments were and I see a hole that has a small phillips head screw inside a larger screw. Which is the high beam adjustment. The low beams are perfect.
Old Mar 1, 2008 | 09:55 AM
bcarrjr's Avatar
2005 E320
No Headlight Adjustment?
I can't believe no one came up with an answer to adjust the high beams on my 2005 E320. Is there no adjustment?
Old Mar 1, 2008 | 10:18 AM
raymond g-'s Avatar
99 E320
with that design, generally there isn't a separate high beam adjustment though
there would be for the low. if the high is pointing to the sky and the low beam
is within spec, I'd look to see if the high bulb is not seated properly
