E-Class (W211) 2003-2009
Passenger side view mirror replacement
Old Feb 29, 2008 | 11:02 AM
RickyEarl's Avatar
2014 E350 Cab
I have 2005 E500 in black. I just busted the passenger side view mirror. The mirror glass is shattered, the clear plastic covering the LED turn signals is gone, and the plastic piece around the outer edge of the housing (surrounding the opening where the mirror glass goes) is split in half on the outer edge.
1. Are these really separate parts or do i just get a whole new mirror?
2. If I buy the parts, is this a repair I can do without spending a whole day or buying some obscure $100 tool that I'll never use again?
3. What should I expect the dealer to charge me for replacement?
Old Feb 29, 2008 | 01:42 PM
Diesel Benz's Avatar
Here you can see which parts can be bought separately:
http://www.detali.ru/cat/oem_mb2.asp...SGR=332&SGN=07
You do not need special tools to disassemble and reassemble the mirror, just some basic knowledge. I believe there are threads with photos showing hot to do it but now that the mirror is "disassembled", you probably can figure out easily how it works.
Old Apr 17, 2008 | 07:07 PM
dhho1's Avatar
2007 E550
anyone knows where to get the replacement mirror parts other than the dealer? The dealer wants $200 with tax to replace the clear lens cover!
Old Apr 17, 2008 | 07:20 PM
konigstiger's Avatar
'71 Pinto
PM Rob: https://mbworld.org/forums/members/28130-kybenz.html and try https://mbworld.org/forums/classifieds/236659-oem-parts-cheaper-update-please-read.html
