E-Class (W211) 2003-2009
those of you with lowered e class
Old Mar 2, 2008 | 02:52 PM
CrimeDoesPay's Avatar
2004 e320
looking for everyone opinion w/ a lowered e class did you guys do it with a spring and shock set up if so what brand and how hard was the install or did you take it to the dealer and have it done and how is the ride quality after the install is it rough and bumpy is it tighter or pretty much the same
Old Mar 2, 2008 | 02:53 PM
t76turbo's Avatar
05 clk 55 conv., 03 E500, 01 E55, 03 F350, FJR1300....
do you have airmatic?
Old Mar 2, 2008 | 03:10 PM
2004 e320
no im guessing if i did i could take it to the dealer and have them do it
i should of gotten a 500 4matic that i was being offerd
Old Mar 2, 2008 | 03:46 PM
mpx220's Avatar
2006 Mercedes Benz E350
Airmatic!! RENNtech ELM is the way to go!
Old Mar 2, 2008 | 05:52 PM
t76turbo's Avatar
I guess you'll need new springs.
Old Mar 2, 2008 | 10:57 PM
j_belll's Avatar
‘23 EQS AMG
H&R Springs. smooth ride, no problems whatsoever *knock on wood* very decent amount of drop.
Old Mar 2, 2008 | 11:01 PM
jimmydagreek's Avatar
2022 CLS450 AMG 4Matic
Btw, where in SoCal would be the best/least expensive place to get the ELM and have it installed??? TIA...
Old Mar 2, 2008 | 11:34 PM
LB Bnz's Avatar
07 E350, 03 Lexus ES300, 04 CLK 320 (gone)
check out HMS (Harbor Motor Sports) @ 714-265-0010
they might be able to help you out...Ask for Edison---real cool guy!!
Old Mar 3, 2008 | 05:53 PM
outtadaloop's Avatar
2004 W211 - 2004 MV Agusta SPR
I got mine lowered using Eibachs at HMS...Jon the owner is a real cool dude as well.
Old Mar 3, 2008 | 06:22 PM
j_belll's Avatar
‘23 EQS AMG
u can try F1 if u dont wanna drive down to the OC
HMS does superb work though, no doubt.
Old Mar 3, 2008 | 06:31 PM
I don't mind driving to the OC one bit, lol. I'm actually down in Costa Mesa/Tustin every couple of weeks because our warehouse down there is moving from Costa Mesa to larger building in Tustin.
On the flip side, I didn't know that F1 did this kind of work. I don't want to spend over a grand on this thing or else I will just take out the sensors and bend them straight to lower the car for nothing, lol.
Thanks for the help!
Old Mar 4, 2008 | 03:35 PM
2004 e320
how much where the springs and how hard was the install
Old Mar 13, 2008 | 03:51 AM
aznflightfreak2's Avatar
2013 C63 AMG, 2015 S63 AMG, 458 Speciale
Hey guys. I also wondered about lowering my 2008 E550. I leased my E class, will the dealer ship or MB charge me when i return my car with aftermarket springs and shocks?
Old Mar 13, 2008 | 03:58 AM
sunkist's Avatar
2003 E320
I'm lowered on H&R sports, I had my MB tech install it while I was in for warranty work. MB Laguna Niguel is the best.
At first the ride was a bit bumpy but after a few weeks they settled into a ride just a tad bit firmer than stock.
Old Mar 13, 2008 | 06:22 AM
Vik888's Avatar
2008 E550, 2012 GL450, 2014 GLK350, 2015 S550, 2020 GLC350e
You have Airmatic .. you could have the dealer drop it about 1" using the SDS (computer).
Old Mar 13, 2008 | 07:50 AM
Tariq's Avatar
S500 W223 2021
I did mine with the dealer, and it looks perfect enough to lower. but are there any disadvantages while lowring, i heard the Airmatic shocks might fail to work.
Old Mar 13, 2008 | 07:52 AM
perishatmyhands's Avatar
2003 E500
just curious...how much would the dealer charge for lowering like that? i want to go a little lower, but the renntech is pricey. TIA and sorry if its a newb Q!
Old Mar 13, 2008 | 11:49 AM
Dieselpowr's Avatar
2005 E320 CDI
Has anyone lowered a CDI? Is the engine heavier than a gas resulting in the need for a little heavier spring up front?
Old Mar 13, 2008 | 01:48 PM
norcalbenz's Avatar
2000 E320
Are there any known issues of rubbing in the front with 20's. I am getting IXI, lago's installed tomorrow with H&R springs, but my installer is suggesting to stick with the 19's to avoid rubbing. I have a 2005 E320, no airmatic.
thanks
Old Mar 13, 2008 | 01:58 PM
sunkist's Avatar
2003 E320
If your car is anything like mine the fronts will not even be any where near rubbing those 20's
My 19's in the front are 245/35/19 +30 offset and I still have .6" gap there a .25" gap in the rear.
So if your gap in the front with H&Rs are the same as mine I really doubt you will scratch...unless your offset is really off as well
Old Mar 13, 2008 | 04:21 PM
How much would the dealer charge me for using the SDS (computer) to lower my E550. If im putting in 20' inch lowenhart should i still lower my car? Will i get wheel bite in the front? Would other people notice that my car is lowered?
Old Mar 14, 2008 | 02:48 AM
Vik888's Avatar
For those of you asking about how much it costs to get the dealer to use SDS to lower your Airmatic equipped car .. no idea. My dealer told me YES but I haven't had time to take it in to get it done.
I also haven't reviewed previous threads on this very topic .. but, I think the most you can lower is 1" and thats pretty much how much your car will lower itself at over 65mph, so I don't see any issues with complications or causing the Airmatic shocks to fail.
There are many threads about this previously, so people have done it. Also, if you lower with the SDS I believe there is no need for redoing the alignment, which *IS* required with the other methods.
Old Mar 14, 2008 | 04:54 AM
j_belll's Avatar
‘23 EQS AMG
thanks
no rubbing whatsoever.
