E-Class (W211) 2003-2009
Windshield washer failure
Old Mar 8, 2008 | 02:06 PM
paulf124's Avatar
The windshield washer on my 2003 E500 stopped worling
No sound from pump.
Does anyone know what fuse controls this and its location?
Also has anyone replaced the pump?
for the help
Paul
Old Mar 10, 2008 | 02:29 PM
jallison12's Avatar
2004 E500 Wagon 4Matic
I had hoped to take this to the grave with me...but in case it might help you.
I had thought my washer pump was bust to. I got my car Oct 2007, so the weather was nice for the first month. I recalled spraying the windscreen when I was test driving it. But when I went to use it for real some weeks later, no wash fluid.
I could wax lyrical some more, but to cut a long story short...I wasn't pushing the button in far enough.
On my 2004 the washer is a push in tip, on the wipers stalk. It will go in some without the washer coming on. If I can describe it this way, there is a soft click (cluck?) when the washer pump engages.
I *almost* booked my car into my Indy for this. But was sooooo glad I didn't. I could never have gone back there again!
Good luck to you!
Old Mar 12, 2008 | 08:41 PM
paulf124's Avatar
Afaid thats not it the wipers run when I push the button.
I have had the car since new so knoe the feel. But thanks
Anyone else have any ideas?
Old Mar 14, 2008 | 02:47 PM
gnma's Avatar
'12 Mustang 5.0, '89 Supra Turbo, C55,
just a quick suggestion: Open the hood, and make sure the washer hose has not broken or full with gunk. Thes hose should lead from the reservoir to the hood. (U'd probably have WW fluid in the engine bay if that were the case).
Also try using a toothpick or pin to clear the holes in the washer nozzles.
Old Mar 15, 2008 | 02:24 PM
paulf124's Avatar
Thats not it the pump doesn't run
maybe a fuse?
Old Mar 17, 2008 | 01:14 AM
daminchi's Avatar
2006 e55 AMG
Well the pump is located behind the passenger side fender.Let me know if you need a pump.
Old Jan 22, 2014 | 08:23 AM
gdinerio's Avatar
26 E53 AMG
maybe a fuse?
Did you ever find the solution to this problem as I am experiencing the same problem. Extreme cold temperatures, tried to use the windshield washer, no fluid spraying nor do i hear the pump going from inside the car. Swore I used it a few days earlier.....
Old Jan 29, 2014 | 09:12 PM
beejAMG's Avatar
W204 C63 AMG, W212 E250 CGI, C207 E250 CGI
I just replaced the pump on my CLK, its a cheap part and relatively easy fix. I think its in the same location with my E but on the CLK its on the front left (RHD) wheel well. Took me longer to remove the tire than to replace the pump.
