E-Class (W211) 2003-2009
avg engine temp?
Old Mar 20, 2008 | 09:49 PM
neyugnj's Avatar
2003 E320
avg engine temp?
hi all.. i'm an mb noob as this is my first mb. my first car was a bmw e30, so i'm aware of some electrical/overheating/etc type problems that can happen in the long run, but that's not really the question here.
i just haven't really paid attention to it before, but the other day while sitting on the 405 in 5pm traffic, i saw the temp gauge on the right read one notch above 80 degrees celsius. is that normal? my car before this was a 99 accord, and it wasn't ever that high, so i'm just asking what it should be.. and if it's fine where it is now. if not, should i just add more coolant to it or what?
thanks in advanced.
Old Mar 20, 2008 | 10:03 PM
AsianML's Avatar
2007 E63
My ML (has the same engine as yours) runs at about 90*C in the summertime, which is about a notch or two above 80 as you stated.
Old Mar 20, 2008 | 10:29 PM
gnma's Avatar
'12 Mustang 5.0, '89 Supra Turbo, C55,
The '08 E350 that was my loaner car ran about 90 deg. which I found to be about 10 deg. higher than my E500. IIRC, it was a tad over the half-way mark on the gauge (that's why I noticed it). But I imagine that is considered normal operating temp. but best thing is to consult your owners manual. It will say for sure what is "normal".
Old Mar 21, 2008 | 01:09 AM
neyugnj's Avatar
2003 E320
oh ya.. forgot bout the manual. i'll try that.
and thanks for the responses. i feel a bit better.
Old Mar 21, 2008 | 01:51 AM
benz_addict's Avatar
V12TT
I dont have an E-Class yet but I can tell you my C230 runs around 90 degrees too, as well as the loaner cars I've had in the past.
Old Mar 21, 2008 | 03:07 AM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
thanks in advanced.
That sounds perfectly fine. If you start approaching 110º then you need to worry, but it could even hit 100º in summer traffic jams with the A/C on high.
Old Mar 21, 2008 | 07:34 AM
Davel's Avatar
03 Eclass, 03 BMW 06 Porsche Cayman S, 03 Harley Davidson "bored & stroked"
be careful, adding more coolant will not make the car run cooler
Old Mar 21, 2008 | 03:36 PM
lkchris's Avatar
'10 CL550, '12 GL550
Yes, you would be.
But, Mercedes dont' have the cooling problems typical of BMWs.
Old Mar 21, 2008 | 03:50 PM
ohlord's Avatar
You
are just fineAfter all the thermostat is set to full open at 87C ,Down in the OC it never hurts to add a bottle of redline water wetter to the coolant tank.Makes the coolant have an easier job keeping your engine cool on those beautiful hot socal days and lubes the water pump at the same time.
Old Mar 22, 2008 | 01:10 AM
E500Newbee's Avatar
2005 MB E500
If the coolant is full, can I just add it to the reserve tank? In the past, I have used this redline product line, from oil to water wetter. It's work. I am a true believer in redline water wetter.
Old Mar 23, 2008 | 06:33 PM
spclagent7's Avatar
2016 E350
On hot days (80 degrees or above) with air conditioning running, my temp runs to 90 degrees Celsius. Never really had it go above that.
With cooler outside temps and/or with no air conditioning, my temp runs around 80 Celsius.
Just checked the 2004 manual. It says that operating temp up to 120 degrees Celsius is fine -- that temps could go that high in "severe operating conditions". Anything above 120, stop the car and get out the manual says.
