E-Class (W211) 2003-2009
will 255/30/20 work
Old Mar 30, 2008 | 05:19 PM
gstatus929's Avatar
2014 E63 S-AMG
will 255/30/20 work
i had some rubbing with 245/35/20 so im changing my tires
tirerack states 245/30/20 in the front but will 255 do?
Old Mar 31, 2008 | 12:19 AM
jimmydagreek's Avatar
2022 CLS450 AMG 4Matic
Depending on your offset and where you rub. If you're already rubbing with a 245 wide tire, your probably still going to rub with a 255. From 35 to 30 your tire is only getting thinner but the width is still there. I would do 245/30/20 as that's what everyone is mostly recommending in here...
Old Mar 31, 2008 | 05:48 AM
takitoz71's Avatar
2004 mercedes E320
I also have 20's on my 2003 E320 and i have 245/35/20ZR Falken FK452 I had to do some modification on the car do to rubbin like u said. u could have 255 but your goin to have to do the same thing that i did on my car. here are some pics of wat i had to do to the car.
Attached Thumbnails will 255/30/20 work-dsc_0031.jpg   will 255/30/20 work-dsc_0023.jpg
Old Mar 31, 2008 | 05:54 AM
takitoz71's Avatar
2004 mercedes E320
lets try this again 2 didnt up load. let see if it works this time
Attached Thumbnails will 255/30/20 work-img_0779.jpg   will 255/30/20 work-img_0782.jpg
Old Mar 31, 2008 | 06:31 PM
gstatus929's Avatar
2014 E63 S-AMG
im not rubbing on the inside, my wheel hits my fender when i go uphill on a turn (pulling in a driveway)
Old Mar 31, 2008 | 07:15 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
That sounds like the wrong offset on the wheel in combination with too much lowering.
