Your favorite surprised feature
![Thumbs up](https://mbworld.org/forums/images/icons/icon14.gif)
When you buy car you expect particular feature set, but sometimes you can discover something unexpected reading a manual, or just playing with a car. For example, when I test drove Jaguar I noticed that navigation map start showing highlighted gas station location when you are near of running out of gas. Lexus of my wife's keeps head lamps on as long as car has doors or trunk opened. Could you provide similar example for MB?
Sun sensor looks like a very good example. I believe old model didn't have it, so A/C started work only when everything began melting down.
2003 E320 Obs Black/Ash
Re: Your favorite surprised feature
2012 CLS
The ambient lighting inside the car is popular with the children and I like it.
The combination of light grey leather and the pano roof - I took a guess having only seen pictures of the E on the internet.
The 6CD changer is pretty cool
The whole look and feel is light years ahead of my 2000 E240
SLK 350 '05
suprised features?! lol. there are plenty.
the night ambient lighting system(great for impressing girls)
the cd-changer door(way cooool!
the little mat for the ash tray (to keep loose change)
the different ride heights of the car when parked(still can't figure it out)
the TURNING SIGNALS!!- when changing lanes, you only have to tap the signal rod once without having it being locked in the "on" position, it will flash the turning lights THREE times by itself. very very cool! didn't have this on my E430.
![Cool](https://mbworld.org/forums/images/smilies/cool.gif)
Also I like the lit segments around the speedometer when you set the Cruise Control.
And how you can adjust the digital temperature of the back passengers but swapping the adjustment with a button to the front.
2000 W210 E55->2003 R230 SL500->2004 W211 E55->2007 997TT+2007 E63->2010 GLK350->2012 E550 4matic
MB Easter eggs
Sun visor which an extending arm to block off lights from the side window.
'03 W211 aka E-500
Where's that?
Originally posted by ValueplusClass
shut out air intake for the cabin almost instantaneously when there is air pollution outside (though manually).
TIA,
EDJ
Yes, its one of the switches on the central console with a car and a circulating arrow on it. Use it for a few seconds to shut out the air pollution from entering the car. (But you have to manually have to disengage it .) If the pollution is a lot more and for a long stretch, the recirculating air function will auto shut off (I believe). Here the charcoal filter would become necessary. To get charcoal filtering, you need to activate it using a different switch.
Cool features
1. If you have the windows/sunroof open and you want to press the recirc button, then keep it pressed for 2-3 seconds and the windows/sunroof will automatically close. When you want fresh air again, press the recirc button again for 2-3 secs and the windows/sunroof return to their exact positions prior to turning on the recirc (even if they were half-way open).
2. Press the "Rest" button after you turn off the car and for upto 30 mins the ventilation will remain on at fan speed 1. You car will stay warmer or cooler (winter/summer) if you just have to dash out for a few minutes to get something.
3. Dual sunshades to protect you from the sun glare if it is coming from the front or the side.
There are many other little things that I am finding out as I get little bits of time to read the manual.
2012 CLS
Thanks also for the note about the recirculate button - I didn't know it opened and closed the windows when kept depressed - I even went out in -7 degrees just to try it!
MORE COOL FEATURES
Originally posted by bmms8
lol
..... and of course holding lock pointing at the front passenger and driver handle look close all the winows and moonroof
lol
Another nice feature - heated seat setting goes from level 3 to 2 in 5 mins, from level 2 to 1 in 10 mins and from level 1 to off in another 20 mins. Never had this in my Lexus. Plus the heat is more evenly distributed than my RX300.
