E-Class (W211) 2003-2009
Very hot front fenders!!!
Old Apr 29, 2008 | 10:29 AM
malgnapa's Avatar
W210 E55 2000
Yesterday I went for a ride here in napa, pretty warm around 90 F. When I got back home In the garage, I felt with my hand the paint in diferents area of the car, just to see how hot it got, the car overall was pretty cool, but the two front fenders above the wheel, almost by the front light's, felt very hot, I mean Very Hot. I have Xenon lights and have them on day time mode. Do you guy's think that's where this mayor heat is coming from?
Please advise.
Old Apr 29, 2008 | 10:32 AM
Benz-O-Rama's Avatar
DAMN!
I thought for sure I was gonna see pics of Lorinsor fenders on your car. What a jip!
Sorry, I have no useful input for your problem.
Old Apr 29, 2008 | 07:35 PM
6hift's Avatar
What's your average temperature reading?
I've been getting a similar problem. When I sit at the stop light the temperature increase to a few bars. The car is at normal operating temperature when it is at 80 degrees but it goes up when I'm still feels as if the car is overheating.
Old Apr 30, 2008 | 03:59 AM
Germancar1's Avatar
2013 650i Coupe, 2010 IS250 AWD, 1999 S500
^^^^ Normal thing. While driving your car is getting fresh air forced into its cooling system, but once you stop it isn't so the temp will move a few degrees (it shouldn't spike eratically) until the ECU decides that the engine needs more coolant then it should come back down. Your car isn't overheating it is merely regulating it own temperature. This is why a lot of old timers used to say let your car run for 2-3 mintues before shutting it off after a hard drive, but modern engineering has obliterated that old notion.
As for the fenders being hot, on a 90' degree day what do you expect? You're driving a car with a V8 on a hot day, heat is coming from everywhere under there and the fenders and everything else is going to get hot. Unless your temp is running hot this is just normal.
M
Old Apr 30, 2008 | 10:21 AM
malgnapa's Avatar
W210 E55 2000
You guy's don't understand, I explain well that all the cars was cool including the hood, the only extremely hot areas where the front fenders, by the lights.
I really think that it has to be a relation with the Xenon light's in use during hot day's. please correct me if am wrong.
Old Apr 30, 2008 | 03:09 PM
JimPurdy's Avatar
11 ML350W2 / 17 GLC300
There is insulation under the aluminum hood that helps keep it cooler than the fenders. I don't have DRL and my fenders get the heat from the radiator and exhaust manifolds.
Old Apr 30, 2008 | 07:20 PM
AMGTTV8's Avatar
2026 AMG GT63 Pro
I am informing you that you are wrong...haha jk...but it is normal...its just heat from the engine..no need to worry about it
Old Apr 30, 2008 | 07:23 PM
AMGTTV8's Avatar
2026 AMG GT63 Pro
ps: very nice in winter ive found, when i have a cigarette outside my car in the cold i sit my a** on the fender and it keeps me warm!
