E-Class (W211) 2003-2009
Sirius antenna
Old May 2, 2008 | 08:56 PM
Piranajoe's Avatar
2003 E500
Sirius antenna
Is the Sirius satellite antenna incorporated in the GPS/Cell Antenna on the 2007 and up E class?
Old May 2, 2008 | 09:50 PM
cyclerider's Avatar
Harley-Davidson
Yes.
Old May 3, 2008 | 10:12 AM
Scambo's Avatar
'13 E550 W4
Do you know if it can be retrofitted to work on the 04 E? I absolutely hate the puck antenna they are putting on the back trunk lids these days, so I won't even get SAT because of that. If they can incorporate it into the new combo antenna style, I will get it.
Old May 3, 2008 | 01:03 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
One can install the Puck antenna under the rear hat shelf with perfect results
Its been done several times on early W211s
Old May 3, 2008 | 01:20 PM
Piranajoe's Avatar
2003 E500
So it would be a direct install/fit where the original GPS antenna sits now on the early w211?
Old May 3, 2008 | 01:34 PM
lkchris's Avatar
'10 CL550, '12 GL550
Since the original sits on your rear window and he's proposing the hat shelf, you can assume not.
The 2007 antenna is roof mounted. The previous blade antennas are glass mounted.
You're pretty much limited to the trunk or the hat shelf idea.
