E-Class (W211) 2003-2009
Old 06-17-2015, 07:28 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Steering and Suspension Guides
Print Wikipost
W211 Shock Absorbers
Old 03-23-2012, 09:18 AM
vettdvr's Avatar
03 E500 and Corvette
check you PM
Old 06-16-2014, 09:30 PM
despicable merc's Avatar
E320
Can it be done without lift?
Old 06-07-2017, 04:09 AM
bizonu22's Avatar
E220 W211
Hello!
I have a MB W211 wagon 2004 with rear air springs and I want to convert it to coil springs.
I also need to change the rear shocks and I want to know if it possible to use other type of shocks. NOT this one
Amazon Amazon
It possible to use normal type (monotube) of shoks? Like this ones
Amazon Amazon
If its possible pls give me some models and some parts numbers.
Thank you very much!
Old 06-07-2017, 07:58 PM
Sleeper Benz's Avatar
W223 S500 LWB 4-Matic, W222 S450 LWB 4-Matic, W211 E500 4-Matic Wagon
FYI: The shocks on the 4-matic wagons with code 489 suspensions are different than ones without. Oh and they cost a lot more. I started another thread about that here:
https://mbworld.org/forums/e-class-w...ar-shocks.html
Old 06-08-2017, 03:33 AM
bizonu22's Avatar
E220 W211
If I will install coil spring I want to put normal shoks(cheaper one). I don't need 4-matic shocks, I want to know if is possible to install normal shokcs without electronics and other stuff on it.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
Quick Reply: W211 Shock Absorbers
