airmatic?
Granted this is my theory. But I have rebuilt many Lincoln's with air suspension ride control height using an air compressor and air springs. I fought one for 4 months doing the work my self before I disassembled one of the air springs by cutting it up. Only then did I find that the rubber had a fold during normal operations where the rubber was wearing. Then a tiny crack formed allowing the leak. As long as the compressor could put in more air than leaked out the car would ride at nomal height. But the Lincoln did not have an alarm for the pump running too long, so you would not know it was running. Only when the car was parked and the air cooled in the air spring the leak would open and the rear of the car would sit on the mechanical stops. This is what I am experiencing in my E500. However as we both know the "dealer" must be the one to find the problem because the customers don't know anything about machines and engineering.!
By the way, I had an 84 Lincoln Continental for 21 years.......I kept it going as my primary work car until finally bought the Benz in 2005.......my wife did have a 1989 Volvo 740 wagon that we used for long distance travel. I had MotorDr. put in a rebuilt engine at about 250k miles and then put another 150k on that motor and it also had a rebult tranny. As I recall, I only had to get the front air shocks replaced once, maybe twice. It was starting to be a challenge to get parts, even used ones, during the last five plus years but I did find a salvage yard in PA that had lots of wrecked Lincolns for parts. Finally sold it in 2006 for $1100 to a young guy who wanted one of these Lincolns and mine was the only one he had seen that still was running with no major problems.
They were all sound cars. This E500 is our first MB and the list of warranty repairs is almost endless. Starting with total SBC failure, suspension,ignition key,,,,,,,,,,,,,,,,, and on. Somehow I thought with MB I would spend less time in the shop but this e500 really hasn't worked out that way.
Given I paid almost 2x what a new lincoln cost I would expect more. What I can say for the most part the dealer has been exceptional and probably the best dealer in 40+ years of car buying.
So would I buy another MB? don't know I would have to check more reliability data.
Would I buy another Lincoln based on reliability YES!.
They replaced the air pump last week and it still collapsed on the rear. Yesterday they replaced the rear air springs both sides. today they are leak checking. Read $$$$$$Remember if the pump can put out more than leaks out of the air spring it will stay level and give a warning. When the air spring leaks faster or long enough you will burn out the pump and or get the suspension too low warning.
I would be really watching to see if the car height changes much after parking a couple of days.
The service dept does a great job and probably the best service dept I have ever used in 40 yrs of buying cars and having them serviced.
What I would not expect for a $70G car is spring failure, ball joint, sbc brakes, ignition key, door locks and the list goes on.
My Corvette bought new at the same time with the same mileage driven on the race track has had ZERO failures.
SO dealer gets Gold Star
E500 gets Red Star
Parts used.
Airmatic compressor 2113200304
Airmatic relay 0025427219
Lines for air suspension 2113270245
Left Rear Air Spring 2113200725
Right Rear Air Spring 2113200825
Seal Holder 2113280058
Screw 19903003
E500 gets Red Star
Parts used.
Screw 19903003
I have the 100000 mile CPO warranty. I looked into aftermarket warranty and they want $2500/yr
. The would not cover the airmatic suspension with less. I just decided to rough it as I won't pay $2500/yr for a warranty to anyone. I would rather put 2500/yr in another car.
I am now thinking of trading the E500 for a new one in about 18 to 24 months given the economy.
Nope,, not too early but I would consider NORMAL.
Cost,, Dealer front shocks $1,100 each,, rear air springs my guess $2500
Compressor,, guess $800.
All of this work was done under my extended CPO warranty for me.
My service mgr told me this was 'normal' failures as German rubber doesn't apparently hold up well in this application. Or so I was told.
I will not buy another car with airmatic suspension for this reason. Too expensive and poor reliability IMO.
While they were inspecting the car, the mechanic also noticed there's a leak in the rear main seal, which separates the engine and the transmission, and the engine oil could leak into the transmission. The repair cost is $1500 and the tranny needs to be taken out for this repair. The rep says I should get this fixed within the next 1000 mi.
I'm thinking of selling this car, although I really enjoy driving this car. I can only imagine that my repair bill will exceed $6000 within the next 12 months, and I expect the other 3 shocks to go bad very soon. And the car is only worth $20k.
I don't know if you can sell the car but values are in the tank due to the poor reliability and the economy. You can do a shock yourself for about $500 if it fails again.
Best of luck with your lemon. With yours and mine we could probably keep one running for a year or so.. Ok,, now I am too critical.
If you can afford the luxury you want new. If not most can't afford to repair them.
