Air suspension collapse
I'll take it to the dealer but it is Saturday and there won't be any techs around.
Any idea what would be required to fix it? Big job, little job?
gOOD LUCK!
I have repaired the seat control (loose connection). Replaced the control valve ($40 & 1 hour in the garage), but I'm concerned about the airmatic.
I was pulling out of the garage when it failed. Same symtoms hissing noise from right wheel well, wouldn't pump up & finally the "car too low" signal. Any advise before I start digging into this new project?
Thanks...
Thanks...
No advice for you other than to get an aftermarket extended warranty. The '03's are infamous for problems.
Good luck with her.
Great service from BEA Motors, Adelaide.
