E-Class (W211) 2003-2009
License Plate Screw Size for Euro Trunklid Insert
Old Jun 3, 2008 | 10:20 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
Question License Plate Screw Size for Euro Trunklid Insert
i just tried to install euro plate onto my euro trunklid insert
the screws that were on US trunklid insert does not fit...
it goes in a little bit then stops...
not sure if it's cuz the paint might've got inside and i should just keep forcing it in or if euro trunklid insert uses different screw size...
any ideas?
Old Jun 3, 2008 | 02:15 PM
lkchris's Avatar
'10 CL550, '12 GL550
It's metric, obviously.
USA size is M5.
If yours is larger, it's probably M6; smaller M4.
Old Jun 3, 2008 | 02:30 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Same screws
It sounds like its loaded up with paint from the Body Shop
I Have several screws (Phillip Head) so When You stop over for the MBENZNL Work I can give you a couple ..But they are the same 5mm 1.25 thread pitch phillip head screws
Old Jun 3, 2008 | 02:41 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
thx mark...
i can't wait that long!
if size is correct, then i'll try to force it in harder (cuz of paint)...
just don't want to damage it...
Old Jun 3, 2008 | 03:38 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
update: i think i have the right screws as 1 of 4 went in fine...
like mark mentioned, i think there's extra paint in the other 3 holes..
what's the best way? just keep forcing it in?
Old Jun 4, 2008 | 02:19 PM
lkchris's Avatar
Tap (from a tap and die set). Thread chaser. Etc.
Old Jun 4, 2008 | 02:47 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
thx!
i'll look into it at autozone...
