E-Class (W211) 2003-2009
is it possible to replace factory Xenon bulb?
Old Jun 16, 2008 | 10:03 PM
sharky's Avatar
My left Low beam went out today and wondering if it is possible to replace it myself?
it's a 2003 E320.
Old Jun 17, 2008 | 12:55 AM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
it's a 2003 E320.
Yes - I hear there isn't much room back there, but it's doable.
Make sure it's the bulb, though. It could be the ballast, etc. Also, if your right bulb is old, they probably will have a different color if you only replace one bulb. Old one will be more purple.
Old Jun 17, 2008 | 09:35 AM
sharky's Avatar
could you please show me how to do it?
Old Jun 17, 2008 | 11:31 AM
Polar Bear's Avatar
I haven't done it myself, but I think it should be pretty straight forward. Just ensure the lights are off (of course) and the xenon bulb should remove very similar to a regular bulb. There is probably a plastic cover that needs to be removed from the headlight assembly (at least there was on the W210) to access the bulb. Just be careful not to touch the bulb with your hands as the oil from your hands can damage the new bulb. Wear gloves.
Old Jun 18, 2008 | 10:40 PM
starbrite's Avatar
2004 E320
It also helps if you do a search. Found this post in about 5 sec :
https://mbworld.org/forums/showpost....05&postcount=2
If it's similiar to a Halogen bulb replacement, note that procedure is in your owner's manual.
Old Jun 19, 2008 | 11:12 AM
MB211's Avatar
2005 E500, 2011 ML350
Before you replace a $100 bulb, swap the ballast from left to right. Make sure the same headlamp is still inop....
This way you know if it is indeed the bulb or a faulty ballast (if problem switches side).
The light comes in/out very similair to a standard bulb, do not forget to plug in the ballast connector.....
