E500 Transmission Problem Follow Up?
Please, fill us in on the details... Thanks!
I remember ajoe and i8hotdoggs having transmission problems. Did you guys take your cars in to the dealer for evaluation? What ever happened with all this?
"Reliability Glitches
But the new E-Class trims are technically complex—perhaps too complex. For example, while I never found reliability to be an issue with a Mercedes, the E320 I tested refused to start for no apparent reason after being parked overnight and had to be towed to a Mercedes dealer.
And the E500 model's transmission got stuck in the "neutral" position while I was trying to shift from automatic to manual-shift mode. The car entered the transmission's "drive" position only after I stopped. Such a thing never happened to me in any type car with an automatic transmission with a manual shift feature. "
Question: does it only happen on the E500?
The wonders and pitfalls of computer wizardry. Hopefully, your incident will never happen again. It sounds like a computer glitch...Mercedes would never let this go if it were something serious... I'm sticking with my order!
I am also leaning towards a one time computer glitch, at least I hope! Either way I do not regret buying this car, I would buy another in a heartbeat. I love this car! I hope your car will be perfect, ENJOY and good luck!
i used the manual-shift mode to shift gears and it worked fine. i brought it up to red-line, shifted, etc. while going fast, i downshifted and it worked whenever safe. if it was not safe (would be above redline), it did not downshift (e.g. i'm going 30 MPH and i try to downshift into 1st gear...heh).
while driving, i put it into neutral, then put it back into drive. it engaged fine and engaged into automatic mode.
i put it into neutral, revved the engine up to redline, then put it back into drive...and it engaged into automatic mode just fine.
so in my tests, everything worked the way that it should.
the only explanation that i can think of for the transmission problem is that when it went back into neutral, the accelerator was pressed really hard so it went beyond redline and the car went into some mode where it decided that the transmission was malfunctioning and then did not allow you to go back into drive. i didn't go this far in my test because i was afraid i might get into a car accident or something.
anyway...i guess this doesn't say too much except that under relatively normal situations, the transmission shouldn't crap out.
Rock
NuBenz,
