E-Class (W211) 2003-2009
Tranny lag when accelerate.
Old Jul 12, 2008 | 12:51 PM
Pekkle's Avatar
2007 E550 Sports
Is there a ECU program that can make the tranny more reaponsive? everytime I want to accelerate aftwr breaking or just plain accelerate from crusing the tranny has at least 1 second lag, before it will change gear. I know it is to provide smooth accelerate. but isnt that the C/S is for?
Old Jul 12, 2008 | 02:22 PM
Barry45RPM's Avatar
2015 ML 350
The C/S switch just determines which program the transmission will follow. C starts the transmission in 2nd, while S starts it in 1st.
Try pressing the gas pedal down a little quicker & further down. It will force a faster downshift.
Old Jul 12, 2008 | 10:30 PM
SPNJHockey's Avatar
07 E350 4Matic / Sport with P1
Apparently, our cars suffer from "drive by wire" technology. That's what causes the short lagging. If you find that you can't adjust to it, a solution would be to install a "Sprint Booster." Search the forums for research info.
Ck your PMs too.
Old Jul 13, 2008 | 09:44 AM
mdreef's Avatar
2020 E450 Coupe, 2022 Porsche Macan, 2001 Porsche 911
Could someone please explain the "learning treanny" feature that our cars are supposed to have?
I was told that our cars learn our driving habits, so if you're driving like a granny then your car shifts like a granny, and if you're driving like an 18 year old (or like me) then it learns to shift faster...
Is that true, and if so, can that feature be disabled? And if it is true, how long does it take the tranny to learn the mode (or mood) you're in?
Thanks!
Old Jul 13, 2008 | 10:30 AM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
Thanks!
Try this from the AMG section to reset the transmission to factory defaults and re-begin the learning process:
1. Turn the ignition key to the on (not start) position.
2. Press the gas pedal to the floor and hold for five seconds.
3. Turn the key to the "off" position (don't remove the key), then release the gas pedal.
4. Wait at least two minutes for ECU to reset.
Old Jul 13, 2008 | 02:14 PM
TMAllison's Avatar
09' E320
In item #2, the key is to depress the kickdown switch.
Keep in mind that wiping memory wipes adaptation values also which are needed to understand any faults the trans may have in the future. They are the techs most important diagnostic tool.
That said, the trans does re-adapt rather quickly (50 miles or so) typically. I wouldn't make a weekly or monthly habit of resets personally nor when having trans problems.
Old Jul 14, 2008 | 06:45 PM
Benzo1999's Avatar
2003 E500 Sport, 1999 ML430 & Regal 402 Commodore
Thanks for the reset tip. I tried it today & it wiped out the lag & twitchiness. It's actually working like my other MB's. I guess the owner before me may have had a twitchy foot...
Old Jul 15, 2008 | 07:24 PM
mdreef's Avatar
I did it today and it seems like "night and day" unless it's my imagination...hopefully I won't get spanked by the dealer the next time I take it in for service and they find out I reset the tranny...
Old Jul 17, 2008 | 03:26 AM
b_rashed's Avatar
2007 S550 (S65 Package)
doing that reset doesnt wipe out the ecu memory cuz i did a ecu upgrade and i dont wnt it to get wiped out if i do that.
Old Jul 17, 2008 | 09:41 AM
NCE500's Avatar
2007 E63, 2006 C55
RE: Acceleration Lag
In addition to all that has been said, my experience has shown that doing the ECU reset on the 07 up cars will help some, but does not have the dramatic effect it showed on my 05 E500. The later cars have a more sophisticated ECU that does a lot more behind the scenes in terms of storage adapting etc.
What I have learned is that your driving style over time is ultimately how your car will perform. By switching to C mode when in rush hour stop/go traffic, the ECU will retain the Sport (S) mode settings that are stored and will not learn the sluggish behaviors from a 10 mph commute.
When not in traffic, I always use S mode, and drive it like a sports sedan, using both full and part throttle kickdown as traffic permits, and not being bashful with the go pedal. My car has excellent throttle response and performance in S mode.
Old Jul 18, 2008 | 06:53 AM
NewMrBenz's Avatar
2008 E350 4matic
I have a sprintbooster on my car and that does not help the lag. Itr just makes your head snap back quicker when it finally downshifts.
What I do is drive using the paddles, then I can control when I want the downshift and downshift earlier.
Old Jul 18, 2008 | 12:29 PM
AMGTestDriverNJ's Avatar
86 190E 2.3-16v, 92 500E, 03 CL55 AMG, 08 E3504M Brabus
This sneaky ECU reset does work. But from what I understand it resets the throttle settings that have been learned, not wipe out all your whole TCU memory. Once reset, if you continue to drive aggressively, the car will stay responsive. However, if you start to drive more casually, ie. stop and go traffic, light driving around town, it will start to pick up on the type of driving you do more often. It is okay to do this reset regularly, you don't run the risk of doing anything harmful but its annoying to do all the time so I do it maybe once every other month on my CL. Obviously, slower cars will not react as much as V8Komp engine but they work across the board. I even saw improved response in my girlfriends old C240 and that thing was a slug!
Old Jul 18, 2008 | 12:48 PM
LRM1's Avatar
2021 E450 4matic
I've had the same problem since I got my car (08 E350). I tried C and S and saw little difference, you slow down for a yield sign or in a turn and when you hit the gas there's a lag. Not so much off the line, but definately when you slow down.
I guess I'll try the reset and see if it works, but that's been my single biggest complaint about this car since I got it, it's hesitation.
Old Jul 19, 2008 | 10:13 PM
K-A's Avatar
K-A
Porsche Macan S SportDesign / Ex M-B's: 11 & 10 & 06 E350's, 02 S500
I don't know if mine has upcoming Tranny problem symptoms or not (just got the Car, CPO'd & 31K Miles). It seems sometimes the Tranny "clunks", I would say it feels like a Tranny slip but I'm pretty sure it's not. I was thinking it was the 7-Speed being slight erratic? I know my S never did this. Sometimes it just kind of feels like it drops out then catches and makes a little clunk, or delay. Again I know these describe Tranny slipage, but is this normal? Thanks.
Old Jul 20, 2008 | 06:02 PM
konigstiger's Avatar
'71 Pinto
Mention DTB P-B-27.60/61i AUG07 Rough shift quality. The dealer should reproduce the condition and identify any mechanical malfunction (i.e.: multi-disc clutch, valve body, etc.), check for software update, and readapt under warranty.
Old Jul 20, 2008 | 06:37 PM
K-A's Avatar
K-A
Thanks konigstiger, I'll do that. Should I tell them taht exact code?
Old Jul 20, 2008 | 06:42 PM
'71 Pinto
They should know what to look for nevertheless yes mention the DTB (Dealer Technical Bulletin) # and request the SA record it in your service narrative to reference in the event of any future transmission concerns.
Old Jul 20, 2008 | 11:44 PM
Polar Bear's Avatar
FWIW my ex-girlfriends CLK350 needed tranny service at about 10k miles due to a clunking effect. It was especially noticeable when slowing to a stop and when it would downshift into first gear.
The dealer went into the transmission and replaced some parts. The last time I rode in the car was at about 30k miles and it was up on lease, and it has started doing the same thing again.
Same 7 speed transmission.
Old Jul 21, 2008 | 12:56 PM
'71 Pinto
If the dealer replaces transmission parts (i.e.: valve body), and you experience problems again the dealer can and should replace the transmission under factory warranty, CPO, and extended warranty. All it takes is a call to Warranty Service.
Old Jul 21, 2008 | 05:13 PM
K-A's Avatar
K-A
Jeez, Polar Bear that sounds exactly like what I'm experiencing. I took the Car in today so I guess we'll see....
Old Jul 23, 2008 | 03:00 AM
MBcruiser's Avatar
2003 E320 Sport
I got 72k miles on my car and I'm getting that same lag effect when braking. This usually happens around less than 10 mph with my foot on the brake, or lightly on the brake, and when I just let it coast. It does it two to three times. Odd thing...is this common to MB's or is it a tranny gettin' ready to fail?
Old Jul 23, 2008 | 08:19 AM
Polar Bear's Avatar
I have not known the 5-speed transmission to have this problem - not saying it does not, but I have not experienced it first hand. I would try the reset procedure to see if it helps.
Definitely will not hurt anything.
