E-Class (W211) 2003-2009
Attempt Comand Retrofit
Old Aug 8, 2008 | 06:15 AM
XJ9's Avatar
XJ9
C350
Originally Posted by Diesel Benz
Gyros are at the Navi processor unit, and I guess you cannot install the head unit in a wrong angle. Although there are some head unit types that integrate navigation and can be used on different models, then you have to adjust the gyro angle accordingly. This should not be an issue for a W211.
correct we are talking about the trunk mounted navi unit... that has to be mounted in a specific position.
Old Aug 10, 2008 | 03:32 PM
scootrz32's Avatar
2003 E320
I havn't bought the trunk mount yet, I was waiting to make sure eveything worked. Maybe that has something to do with it. Will try it out.
Old Dec 16, 2008 | 05:43 PM
m3tonyh@verizon's Avatar
'03 E55
Originally Posted by tashakes
Diesel-Benz is right there is tons of info, just to be more specific (nothing better to do :-) :
I have tele-aid and a harmon kardon system.
-YES!
There is already and antennae on the car, can I assume that was from the tele-aid and will work with the Navi?
-YES
Do I need a audio gateway even witht the harmon kardon system?
-NO, it is already there.
I do need the bracket and trunk liner I know that for sure.
-NOT NECESSARILY, I mounted mine under the parcel shelf. See pic.
Do I need to run a fiber cable to hook up to the MOST in the B
pillar?
-NO, it is already there, what you have to do is connect the cables in the right sequence. You will need access to the bottom of the B pillar and under the rear seat.
You also need to take a look at the posts to figure out if your car is prewired for navi, not all 2003 cars were.
Cheers.
Hi,
I know this post is kinda old now, but how can I tell if my car is pre-wired for nav or not. I have a '03 E55 production date of 04/03. What and where should I look? Thanks alot!
Tony
Old Dec 16, 2008 | 05:45 PM
'03 E55
03 Navi instal question
Hi,
Tony
Old Dec 16, 2008 | 06:03 PM
konigstiger's Avatar
'71 Pinto
Originally Posted by m3tonyh@verizon
Hi,
I know this post is kinda old now, but how can I tell if my car is pre-wired for nav or not. I have a '03 E55 production date of 04/03. What and where should I look? Thanks alot! Tony
Read this thread in its entirety
https://mbworld.org/forums/e-class-w...it-w-pics.html
