how to you avoid the dead battery after you have a long vacation ?
This probably is a good record -- one month. I will consider having longer vacation now.
Both you and Gethen mentioned that it will not be a problem for a new battery but my car battery is getting older after years while my vacation will not be shorter. Is there a long-term solution? I know I can always call MB roadside assistance for replacing a new battery free within my warranty.
which I did it before but I had to drive my car back to the service center to reset settings after replacing a new battery.
Otto
You are right for most of MB models but I just confirmed with my local dealer, the technician said the trickle charger does NOT apply for the new e models because there is a chip inside the car is not compatible with the current MB trickle charger.
and he suggested I disconnect my battery before I go to my vacation and synchronize both windows and roof after reconnect the battery.
I believe the trickle charger for new e is on the way, I definitely will get one after it is available. Does anyone when it is available and the part number?
Thanks.
Otto
I was told that I could disconnect the battery in the trunk as long as I want and I believe this is the one to provide the electricity power for start engine. The other one holds all memory setting, e.g. my memory seats, radio stations, etc. When I reconnect back the battery in the trunk, the only things that have to do is reset/synchorize windows and roof.
The way you resynchorize your windows (4 of them) is
after you reconnect battery, press window button down and hold it 3 seconds then press up. (you have to 4 of them)
for the roof, press open button then it will pop up and hold the button 3 seconds then you close it.
I hope MB comes out trickle charger for new e soon. I don't want to get a shock when I disconnect my battery in the trunk. By the way, after fully charge your car battery, you always get better lights and sound quality. especially, for those who drive car in a short trip daily. (it should be charged over night every 2 weeks or 1 month depends on how short your daily trip is and how you consume the power, e.g. heated seats, lights, etc.)
Otto
if it's a 2 week trip, i would keep the battery connected, lock the doors, but not enable the alarm. if you have your own garage, it should not pose a large security risk. the alarm uses up some battery (much more than the other stuff that it uses while shut down).
Rock
I have an old Vette with a 3 years old battery. The car has been sitting outside since Sept.5th and we had very cold weather (minus 22deg) for a few days)
I started the car this afternoon to put it in my garage for the winter. It cranked righ up. 2 -3 weeks on a new battery is nothing
jackD
What the heck does that mean? Someone fill me in...
Thanks!
NuBenz, it means make the windows re-remember how to one button press to go all the way down with one touch and same for up.. as well as the sun roof one touch function.
What do you mean if you know how to do them yourself?
and how?
if you replace a battery, it is NOT only resynchronize both windows and roof, you have to reset your break, etc. -- it is controlled by electricity, after you lose electricity, it works by press pedal harder but for safe reason, your car will display malfunction of your break and ask you to visit service center. I believe you have to use a computer/laptop from service center to reset it. actually, if you lose electricty totally, you will find you CANNOT turn your key to start the car, system locks the car for your safety -- you have to call roadside assistance but after a battery replacement, the technician will ask you to visit the service ceter as soon as possible.
when I said disconnect the battery in the trunk, you only disconnect the negative cable from the battery -- the one close to the you. hopefully, I do NOT mislead everyone for the definition of "disconnect" battery.
Otto
there are more information on page 344
this page also answers NuBenz's questions
2. you can no longer turn the ignition key or, in cars with keyless-go, pressing the keyless-go button on the gear selector lever has no effect.
3. the gear selector lever is locked in the position P.
2. resynchronize the front seat head restraints, page 104.
3. resynchronize the esp, page 75.
4. re-enter the radio code.
5. resynchronize the side windows, page 186.
6. resynchronze the sliding/pop-up roof, page 189.
on page 75, does anyone see the way to resynchronize the esp ???
the easy DIY way as I known so far is drive it back to service center.
as northbenz said, the trickle charger is the solution and I hope it is available soon. with this accessory, you can
1. have a looooooong vacation, i.e., one year long.
2. make your battery life loooonger if you charge it bi-weekly or monthly.
3. better sound quality and brighter lights.
Otto
but I got the price quotation of current MB trickle charger, $67, plus tax. the installation fee is $95 times 1.5 or 2 hours. (labor $95 per hour and it takes 1.5 to 2 hours to install it.)
northbenz, could you comment on it?
thanks.
Otto
But I would like to hear more on the subject. I am considering buying the new E55 (in Europe) but it will have long dormant periods. Normally, my storage guy disconnects the battery (of my 500E). This has worked a treat, but I am not sure I will be able to do the same on the next car.
after reconnect back the battery, if you do not want to mess up with the electrics, just drive your car to a local dealer who can reset the settings within 10 minutes -- it is free.
otto
NOT EVERYTHINGS NEEDS RESYNCED AFTER A BATTERY FAILURE.
THE ITEMS IN THE OWNERS MANUAL ARE SUFFICENT.
OH AND BY THE WAY TO RESYNC THE ESP/BAS,START CAR AND TURN STEERING WHEEL ALL THE WAY TO LT AND THEN BACK ALL THE WAY TO RT .
ANYTHING ELSE I CAN DO FOR YOU JUST ASK....
