E-Class (W211) 2003-2009
Can someone please tell me how to change spark plug wires for my 2003 e 500
Old Aug 12, 2008 | 06:08 PM
bjones5833's Avatar
E500
I need help replacing the spark plug wires for my e 500 can someone give me info or instructions on how to do it.
Old Aug 13, 2008 | 12:38 AM
lkchris's Avatar
'10 CL550, '12 GL550
You could of course subscribe to WIS for a day or purchase the W211 service DVD in which you'll find the procedure which lists the special tool required. Mercedes recommends the mechanic get out his old 17 mm offset open end valve adjusting wrench to use to pry the plug wires off the plugs. Then, you'll need a wobble extension plug socket.
And, while you're at it you'll want to look up the procedure for removing the airbox and adjoining hoses.
BTW, last time I checked (couple years ago) these wires were $24 each from Mercedes so 16X24 = $384 for the set. Mercedes doesn't specify a change interval.
Old Oct 14, 2008 | 05:04 PM
msobug's Avatar
1997 E 320
Hello, What is WIS ? is that like alldata ? I have a 97 E320 ... do you know is there is service manual/DVD for this ? Thanks
Originally Posted by lkchris
You could of course subscribe to WIS for a day or purchase the W211 service DVD .....
