Do I need a new tire
and if I do I have to get the same one and michelins the most expensive one
it's the front tire, just got the car 4 months ago (08 e350)
At least this way, you have the option of conveniently and comfortably getting the tire changed, rather than waiting for road service, or doing it yourself on the shoulder of the road, possibly in the rain when you are on your way to somewhere. Since the other tire is almost Brand New too, just replace your tire with the side wall damage if a couple of tire shops say its more than just a surface bruise.. its hard to tell from a picture.
Just do the bad tire ASAP:
1. The good one(s) only have 4k on them (almost new if you're not hard on them)
2. When it comes to sidewalls, you can't take a chance with a blow out.
(And, the mfr. probably won't do warranty on it - due to damage to the sidewall...in other words: you "eff-ed up" the tire.)
Why would Michelin cover curb/pothole damage? Would call SONY if your plamsa tv fell off the wall and cracked? Warranty does not cover physical damage......
That gash is pretty high up on the wall. I would recommend replacing it. With only 4k on the tires it would be wasteful to replace the other one. The wear in that tire should be minimal at this time, and not enough to make a difference.
he said the sidewall is about 2" thick, if there's no bubble or threads showing he said I shouldn't worry about it. I'm still kinda stressed about it
I don't recall ever hitting a pothole or curb,
I don't recall ever hitting a pothole or curb,'Nuff said!
My question is about "blowouts" Since radial tires became popular I have never suffered a "blowout". This is a traumatic event that you won't soon forget. I think most tires fail from air loss then heat build up and finally sidewall failure. This process happens over time and an observant driver might catch the problem before it is total failure. I define a blowout as an instantaneous and total loss in air pressure and simultaneous disintegration of the tire carcass. Occasionally I see blowouts on 18 wheel truck tires and they are dramatic. No question that sidewalls are the achilles heel of modern tires. The Firestone incident has turned tire repair into the absurd. I quit trading with Costco for tires because I refuse to be scolded on tire speed rating and axel placement of new tires.
If the cord is cut replace it immediately. The cord provides the strength to the tire sidewall and the rubber is only a small % of the strenght. So if it isn't cut through the cord consider putting it on the rear and driving on it.
If you can pull the rubber back and see the cord I would replace just 1 tire.
So I just ordered a new tire $310
Should I keep the old one??
If it is safe drive on it, if not dispose of it.
Seriously, if you ever wanted to mount the tire again, most credible tire shops would likely advise against it once they see the sidewall cut- lose the old tire and let costco recycle it.
QUOTE]Get 7 more tires and a monkey bar set, then you're ready to train some Al Qaeda.
