AMG CL Wheels on E500
Re: AMG E55 Exhaust
Originally posted by benggolf
Muhri2, some welding and re-fittting will have to be done to install the AMG 4-pipe exhaust system. Any good muffler shop should be able to do it without problem.
The downside maybe a loss of torque on the bottom end because of less backpressure given the larger diameter exhaust pipes. The final look is really impressive though.
2010 Prius & Miata MX5 PRHT, 2010 Toyota Venza AWD, 05 C55 AMG, Yamaha 1100 Custom, Honda 250 Reflex
In that case....
Originally posted by muhri2
hrmm.. loss of torque - dont want that to happen it only has 240 nm of toruqe it'd be bad to sacrifice any of that hehe.. Will it change the sound of the engine though (more throaty)?
Past experience with AMG C32 exhaust mounted on my C320 made a very slight improvement in the sound department; hardly worth the effort and money really. Also noted a slight loss of torque at low end.
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
1 Post
Honda Accord EX V6
Lowering
Hi, Stevo first of all nice car and rim. I believe that's 19 inch rite.. Do you lower your car? if not, is there a big gap between the edge of the tire and your body? Because i was planning to put 19 inch brabus monoblock vi multi piece on my car. and I wasn't plan to lower it. I got the wheels and rim for $4500
E320
Re: Lowering
Thanks for the compliments. I didn't lower the car, and I don't have the sports package. There is a gap, but not too bad. If it was really bad I would definately do suspension mods, but it's really not necessary. I like the way the car drives as is, therefore I'm not going to be doing any suspension mods. Brabus mono's would look sick on that car
