E-Class (W211) 2003-2009
Electronic Trunk Closer
Old Sep 24, 2008 | 12:20 PM
MB_E500's Avatar
2006 E500
Can the speed of the electronic trunk closer be adjusted? When I hit the close button it flys down in about 3 seconds. My pal has a BMW 750 and his closes very smoothly and slowly...I think slower is safer and less stress in the long run on the mechanics of the system......:
Old Sep 24, 2008 | 12:38 PM
andys10's Avatar
'06 E320 CDI,premium package, xenons,LED's,Nav. and '11 BMW 335 D, Nav, Sport, Premium, Cold, PDC
I have this problem on my 06 320 CDI.
It was working fine for a year or so (gently opening and closing) and all of a sudden started acting up on me – opening very fast and slamming hard when the “close” button is pushed.
Took it to the dealer and currently waiting for the “module” – they are on back order. Repair will be under warranty.
Old Sep 24, 2008 | 01:15 PM
MB_E500's Avatar
2006 E500
Good to know. I will take it into the dealer. Thanks for the tip!
Old Sep 25, 2008 | 04:33 PM
Eddie Knopp's Avatar
2013 E 350, 2012 GLK 350, 2012 C300 4matic
I had the same thing happen to my '04 E55
Old Nov 10, 2008 | 12:54 AM
Pekkle's Avatar
2007 E550 Sports
What's consider normal speed? my is not super fast, but it certainly does not close gently.
Old Nov 10, 2008 | 07:01 AM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
You should be able to adjust the speed in which it closes by removing the trunk liner and changing tension of the springs by moving them over a hole or two.
Old Nov 10, 2008 | 10:41 AM
tyltan's Avatar
I have electronic trunk open. I didn't know you can close it with your remote. Is it an option or I didn't know how to use it?
Old Nov 10, 2008 | 11:34 AM
Barry45RPM's Avatar
2015 ML 350
There is an option for electric motor closing & latching of the trunk lid. What you and I have is an electrically operated solenoid switch that pops the trunk release & the lid raises by spring tension.
