E-Class (W211) 2003-2009
changing Saved radio station on steering wheel
Old Sep 26, 2008 | 04:10 PM
deadalous's Avatar
w211 Mercedes E230 2003
Hi there,
i have a mercedes E320 2003 and the problem is i am not able to change radio stations(the ones saved on memory) from my steering wheel buttons, it only searchs manually once i click the next button from my steering wheel,but i wanted it to switch between the channels saved on memory.
is there any way to make this?maybe from the menu?
i appreciate your help.
thanks
Old Sep 26, 2008 | 05:25 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Please search since this has been discussed numerous times.
Old Sep 26, 2008 | 05:27 PM
Barry45RPM's Avatar
2015 ML 350
Originally Posted by deadalous
Hi there,
thanks
Can't do it on a 211 untill Model Year 2007. Your car will only scroll to next available receiveable frequency.
Old Sep 26, 2008 | 08:12 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
My 2006 W211 has saved station feature..after SDS version code work
Old Sep 26, 2008 | 09:43 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Mark, if you make statements like that you must clarify that it isn't available to everybody at a moments notice.
Old Sep 26, 2008 | 10:03 PM
I Stated that IT CAN Be Done VIA The SDS ...
Hi there,
thanks
Didnt see The OP asking for EVERYONE or How long it will take
If so Please correct me...
Old Sep 26, 2008 | 11:08 PM
konigstiger's Avatar
'71 Pinto
To the best of my understanding 03 through 06, "MBUSA dealers" can add the choice to switch between preset (saved) and frequency (next station) to the MFD through SDS however, even when doing so the preset choice continues to scan frequency.
Old Sep 27, 2008 | 05:50 AM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Hi there,
thanks
Mark, you keep stating those kind of answers all the time without regard to the asking member's locations and the associated dealerships capability. Just because of your location, your access and associated costs you expect everybody else to enjoy the same privilege. You know very well those inherent limitations of your statements in that regard.
Old Sep 27, 2008 | 07:33 AM
deadalous's Avatar
Smile
Hi, and thank you all for posting
I am located in lebanon, could you please clarify a little that SDS thingy :o
does that mean i can reprogram my cluster so this options becomes availble?
please let me know if i am right.
thanks
Old Sep 27, 2008 | 07:45 AM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
It is highly doubtful that your dealer will be able to perform this to your wishes. You yourself would not be able to. Please reread konigstiger's post above.
Old Sep 28, 2008 | 01:15 PM
deadalous's Avatar
unfortunately i am giving up on it, i will just do like you and enjoy driving it atm
thanks for all the people who shared their knowledge.
cheers
