Want to add Parktronic to my car
Folks,
I almost touched the bumper a few times while parking in the garage ... Need help if I can install park sensors in the bumpers, install the shifter base with P))) button, dist info LEDs (dont know where'd they go) .... its sn $1140 option on mbusa ...would they install it in my car ? Anyone's done it in Chicago area ?
thanks all
thanks all
Folks,
thanks all
thanks all
Forum members have done it or have had it done by retrofit experts. It isn't going to be cheap but I'd look at it seriously.
'12 Mustang 5.0, '89 Supra Turbo, C55,
I've seen "parking blocks" in generic automotive stores. You park on them, (u feel the groove as your tire drives on it), and presto, perfect parking all the time, and no fear of hitting your garage. Never used it, but it seems pretty simple enough.
OR,
have a spare tire lying around? Use that as cushion bet. your car and garage,
OR,
after parking in the "proper" place, reference a point in your garage from your drivers window or side mirror, and when you're at that point, you're done! Thats' what I do. Don't have a referernce point? Make one. Playboy centerfold works great!![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Why spend $$$????
OR,
OR,
Why spend $$$????
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
He was not going to spend money "on a reference point".
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
I would agree if it was only for the garage but I assume he is parking the car elsewhere too.
209/W210 Estate /W211 modded by MBENZNL
Several here have added Parktronic after the purchase of the car
It WILL cost more than ordering the car with it
As it requires a LOT of labor
Remove the dash to mount the front display
drop the headliner for the rear display
remove both bumpers
add the wire harness and control unit
MBENZNL.com did the retrofit on my W211
remove both bumpers
Folks,
thanks all
thanks all
http://www.liftmaster.com/consumerwe...px?modelId=826
Alternatively, you can buy a generic version that works with all garage door openers:
http://www.smarthome.com/7187/Laser-...-System/p.aspx
Note, that it's best to aim the beam at an interior point, as it's hard to see it on the exterior due to reflection off the paint.
Talk about crazy parking
Thats my Bluetec parked in my garage
; every time. No gadgets, no lasers and I also reverse in at an angle since my drive curves out to the left out of the garage. No mishaps so far. Did you see my garden implements almost on top of my MB? I know I should move them out to the other side or my shed
![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
2015 ML 350
If you're concerned about garage parking, pass a string thru a tennis ball & nail (hook) the string to the ceiling at a point that will allow the tennis ball to touch your windshield when you have pulled in to your desired distance from the wall or wheel stop or whatever.
2015 ML 350
...and you can't trip over the tennis ball like you can the wheel chocks when the car is not in the garage.
Its low tech, but non intrusive to the car or the wallet.
