E-Class (W211) 2003-2009
Nav Help
Old Oct 12, 2008 | 08:58 AM
djmallya's Avatar
03 E320/ 11 E550 Cab/ 18 E400 Cab
Nav Help
I just installed a nav dvd but it keeps saying no disk or nav activated please wait...
Did I do something wrong?
Old Oct 12, 2008 | 12:27 PM
Barry45RPM's Avatar
2015 ML 350
Is this a replacement DVD or your first one? Was it working properly before? Is it a legal original disc or a copy? If it's your first one, you did put it in the NAV drive in the trunk & not in the COMAND unit, right? You don't give much info in your OP.
If you're experienced in this & the disk is inserted correctly its possible you need a software update.
Old Oct 12, 2008 | 02:01 PM
Diesel Benz's Avatar
Or do you mean you installed the Navigation drive, not only the navigation DVD? A bit more info would be useful as Barry mentioned.
Old Oct 13, 2008 | 09:24 AM
djmallya's Avatar
Sorry for the vague post, I installed a new nav drive w/ burnt dvd, in a car which did not previously have navigation. I used procedures from elsewhere on this site to add the truck nav fiber optics to the optical loop then had the dealer activate the nav options with star.
The only thing it does is say navigation activated, please wait or, if I take the disc out and put it back in, it says no disc inserted(boot)... it's a euro.
Old Oct 13, 2008 | 09:42 AM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
There have been posts that copied/burned discs don't necessarily work. Plus you have to make sure that the SW in the components is compatible with the NAV disc version.
Old Oct 28, 2008 | 03:46 PM
pl626's Avatar
2015 E400
I'm getting the same message, but the DVD Nav came with the car. I have a US spec 2006 E350, but the DVD is stamped 2008, though it says it's for MY04 - MY08 E-Class. So it should work, right? Is there a system reboot I need? Thx.
pc
Old Oct 28, 2008 | 04:12 PM
pl626's Avatar
2015 E400
No worries, I cleaned the DVD surface, popped it back in and this time it was successful. BTW, this was the US DVD V7.0.
