E-Class (W211) 2003-2009
Pics of "washer lowering"
Old Oct 25, 2008 | 02:46 PM
RyanPaul51's Avatar
04 E320
Can someone post pics of the "washer lowering method". It sounds easy enough, but I'd like to see what I'm supposed to be doing. (I've done plenty of searching, and I couldn't find a thread with working pics) Thanks!
Old Oct 25, 2008 | 08:41 PM
Benz-O-Rama's Avatar
Originally Posted by RyanPaul51
Can someone post pics of the "washer lowering method". It sounds easy enough, but I'd like to see what I'm supposed to be doing. (I've done plenty of searching, and I couldn't find a thread with working links) Thanks!
Does your E320 have the airmatic suspension? It wasn't standard on your model. You must have the airmatic to do the washer lowering.
Old Oct 26, 2008 | 01:26 PM
RyanPaul51's Avatar
04 E320
That's almost a little insulting, haha. Yes, I have the airmatic suspension.
Old Oct 26, 2008 | 08:11 PM
How hard did you look? With one search of "washer", this was the first thread I clicked on:
https://mbworld.org/forums/w211-amg/107267-lower-your-e55-20mm-0-8-80-cents.html
Pay particular attention to post 14.
Also, you are aware of the catastrophic failure that can happen with this mod, right? When you add washers, the amount of thread for the nut to tighten on, are severely limited. And if that nut comes off, at say 65mph, it's gonna be ugly.
That said, I did this mod without any issues for about 6 months.
I would recommend lowering links from www.adjustableairride.com or a RENNtech lowering module.
Old Oct 26, 2008 | 11:44 PM
RyanPaul51's Avatar
04 E320
Originally Posted by Benz-O-Rama
How hard did you look?.
I actually thought I did a pretty good job! Apparently not!
After looking at those pics, that mod looks kinda sketchy. Thanks for the help!
Old May 26, 2009 | 08:41 PM
jgdynamics's Avatar
E500,CLK500K, E55
hey benzorama, you lowered your rear by only 20mm? and you are tucking tire? did any of you decide to replace the standard bolt with a longer one?
Old May 26, 2009 | 08:54 PM
No sir. I ended up spending the money and lowering it the right way, with the RENNtech ELM.
