How to remove 48 lbs of unsprung weight...
06 E500 sport
I just changed my OEM staggered double-10 spoke 18" wheels and tires for a set of 17" fat-five OEM's w/ new 245/45-17 Michelins PS2's.
The replaced tire/wheel combo was Nitto INVO in 245/40-18 front and 275/35-18 rear on the original (3/06 build) E500 sport wheels. I guess the wheels used in the later built 06's are the same as the 20 spoke (dual 10 spoke) that the newer E350 sports use. Tires had about 90% tread left (3,000 miles use)
Ok, here's the weights:
Front OEM 18" wheel and tire was 54.5 lbs.
Rear OEM 18" wheel and tire was 56.5 lbs.
New 17" wheels and tires are 43.5 lbs each
The car feels faster and smoother! Apparantly removing almost 50 lbs of unsprung and rotating weight can really help the ride and acceleration!
18's be heavy!
18's be heavy!
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
18's be heavy!
18's be heavy!
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
Wow, does that mean that the factory cast fat-5's weigh only 19.5 lbs each? That's very light for a cast wheel meant to carry such a heavy car.
Tirerack lists the weight of a 245/45/17 PS2 at 24 lbs.
W210 E55, W211 E3504M, E90 325i
Damn the 18" double-10 spokes weigh a lot!
I'm not at all surprised, I changed remounted the factory wheels the other day and was struggling to lift them up and position them on the hub. I thought they weigh even more than the 18" setup on the 3 series (E90) with the heavy factory RFTs.
Are you referring to the 18" 10 spoke rims that come on the 07-08 w211s with sport package?? Those are 42lbs each(Actually lighter..thats what they weighted in a box). I weighted them and they were weighted at a UPS facility.
EDIT: Didn't notice that weight was with tire. Yeah with tire it could be that high.
06 E500 sport
My build date was 03/06 and my E500 sport came with those wheels from the factory.
H
On a side note, a set of 19" VIP Modular VR05's wrapped in 245/35 and 275/30 Toyo T1R's weigh in at 50.0lbs per corner. On the flip side, my 18" OEM E63 (P030-2piece) wheels wrapped in 245/40 and 265/35 Falken's weight in at 59.0 lb's per corner. Sucks gaining 40lbs of weight when going to smaller wheels.
VIP's FTMFW!
![Wootrock](https://mbworld.org/forums/images/smilies/wootrock.gif)
I recently did a brake job and came accross porforated aftermarket rotors ... I didnt weigh them, but it was 2/3rd if not half the weight of OEM rotors .... I think I can get away with another 8 lbs per rotor atleast (32 lbs) ... those were $150 each thou
04 E320 4 Matic, 95 Audi S6, 99 Carrera 4 Cabrio, 12 Fiat 500 Sport, 00 BMW R1200C 10, BMW R1200R
18's be heavy!
18's be heavy!
I can cut about 4 lbs. per tire by switching tire brands when I replace the summer 245 17s. I will do that for sure. Another thing that people don’t know about unsprung weight that spins that eliminating it actually increases the brake efficiency by a lot! Depending on the unsprung weight you eliminate (spinning dynamic versus not spinning static), one pound of unsprung weight equals up to about 9 pounds of sprung weight! This all makes a difference for people who are capable of telling and appreciate it.
What is keeping me from going bigger than 17s is that I hit A LOT of pot holes in this area. I really don’t want to go bellow a 45% aspect ratio (yet).
Thanks for the post! You are bringing up a very valid point that is often overlooked.
Steve
