Xenon Startup
Do they move up and down and side to side when turned on, or only up and down? I have read posts where some move side to side when turned on, but my 2005 does not do this.
They do move side to side when driving so they are working right - just wondering about startup.
I believe the active xenon lights have had two different implementations. I do not remember the time when this was changed but some (early) xenons did the start-up calibration in two dimensions while the current ones only do this for the vertical dimension. My W221 does it only vertically and still has those active turning xenons.
When I fire mine on, the xenons flip up, and then do a side-to-side dance for a couple of seconds.
Late W211s go u/d only on start up
Correction
Model Year 2004
Up and down only and only on start-up. No side to side movement except when car is turning and moving.
Right or left fog lamp goes on when right or left turn signal on or steering wheel is turned right or left. Fog lamps are "corner illuminating." They actually direct their light towards the inside corner of the turn. But they don't seem to swivel themselves. I think they just project their light differently when you turn(?) But they definitely aim light towards the corner. Very effective when turning into unknown dark driveways.....
Anyway, the latests posts already clarified when the implementation was actually changed (and that there are lights with different behaviour even if both have the active curve light feature).
The early implementations were controlled by the front SAM via the LWR-BUS, later implementations have a direct CAN bus connection to the xenon control unit but the LWR control wire still comes from the front SAM.
