E-Class (W211) 2003-2009
Electronic Trunk Closer - DIY?
Old Nov 4, 2008 | 10:42 PM
Mackhack's Avatar
Hi guys,
just a quick one... How much would it be to put the electronic trunk closer in and can it be done myself easily?
Old Nov 5, 2008 | 06:04 AM
rob13572468's Avatar
PREMIUM SPONSOR
ML350, Lotus Elise
Originally Posted by Mackhack
Hi guys,
It can be done.. ive done it but it is by no means a DIY job. The entire harness for the closer electronics has to be fabricated and that in itself is a big deal. After that the whole trunk comes apart to install it and finally the car has to be SDS coded for the closer to work.
Old Nov 5, 2008 | 09:40 AM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Steve @ MBENZNL.com did mine
It Is a LOT of work to install one
Also Needed is a inside trunk release switch and a rear trunk panel with the trunk closer switch..if the car has keyless go you will need another switch
Old Nov 5, 2008 | 01:47 PM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
It's really not worth it, the option that is. Have it on our CL500, the thing has broken twice. POS, I'm afraid to use my trunk. And the nice thing on the E-s is that the standard trunk pops up all the way unlike some benzes like the SL.
Old Nov 5, 2008 | 01:54 PM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
I've gotten used to it - I guess if you have never had it you won't miss it. But looking at other E's and being used to Bi-Xenon, Keyless-Go, Trunk Closer, etc, it's discouraging knowing I would miss many of these options.
I have a CDI, and am looking to add an E500/E550 4-matic.
Old Nov 6, 2008 | 12:34 AM
Mackhack's Avatar
Agreed. I like my pop open function as well. Use it daily! Alright then I guess I just ignore it!
Thanks guys for the insight!
