E-Class (W211) 2003-2009
Navigation Question
Old Nov 16, 2008 | 11:35 PM
cmykdesign's Avatar
05' E500 Sport, 01' CLK 320
Navigation Question
I've been looking at E500 2005 models and the one I want to buy has the Navigation unit (US) but no DVD controller (??) in the trunk. What do I need to make this work and how much would it cost?
Thanks!
Old Nov 17, 2008 | 12:23 AM
Barry45RPM's Avatar
2015 ML 350
How do you know it has navigation? A large screen on the dash's Comand Head Unit is standard whether or not the car has NAV. If it has NAV, it has a Nav DVD Drive on the left side of the trunk/fender wall.
Old Nov 17, 2008 | 02:13 AM
cmykdesign's Avatar
no dvd in trunk
yeah.. it only has the unit screen that's it with the Nav button so I assume it works and just needs the DVD unit in trunk. A little confused on this one...
When Steve did my CLK W208 he put in a Euro unit so not sure about how it works with the W211.
Old Nov 17, 2008 | 08:43 AM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
What does it say when you press NAV or MAP? It should tell you that there is no NAV unit installed. you may have to replace the trunk liner depending on the car, and install the DVD processor, which is essentially the DVD drive, and place it in the MOST ring and have it version coded at the dealer.
Old Nov 18, 2008 | 02:51 AM
cmykdesign's Avatar
pick up this weekend
Not sure.. I will check this weekend when I pick up the car.
