E-Class (W211) 2003-2009
New Message In My Dash
Old Nov 20, 2008 | 12:21 PM
ruffrob's Avatar
2010 Charcoal Grey E350 Coupe
Car got towed last night due to some 'emergency construction' and upon getting it back,I'm now seeing a message saying something like 'Battery something,Normal Operations' What do you guys think this is. Thanks in advance to all who reply....
Old Nov 20, 2008 | 03:00 PM
Clinton Horn's Avatar
2003 E320
The car is powering down accessories that it cannot handle due to some problem in the electrical system. It will start with nonessential accessories and keep climbing the ladder with shutdowns as the drain continues. This is to gain time for the driver to get it to a safe place.
There are several causes that keep cropping up on these cars
Voltage Reg failure and alternator problems appear to be most common
You can run a search on this forum. It is a pretty common warning message.
Mine did this because of a loose battery cable but I was lucky.
You may be able to retrieve a fault code if you are capable of running the diagnostic. If you have little or no maintenance talent, you probably should head to the dealer during daylight hours.
I have never heard of this problem correcting itself.
Old Nov 20, 2008 | 03:25 PM
xr650rguy's Avatar
06 E500 sport
Need advice on winshield wiper problem (not working sometimes)
'06 E500
When I use the sprayer (two clicks in), the water sometimes shoots and sometimes doesn't. When it does spray, the wipers work. When it doesn't spray, they don't. The mist function (one click in) works the same way, intermittently.
When I twist it, they work most of the time, but not always. It's frustrating.
Has anyone had this problem before?
Also, I've run out of water in the past and there's no indicator that the washer fluid was low. Does the car have an indicator of any kind?
Old Nov 20, 2008 | 11:12 PM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
Can you see exactly what the message is? If your batteyr is below 12.0V or so, you will get a "Low battery - Convenience Functions Temporarily Unavailable." Once the battery is sufficiently charged, you will see a message that something like Note:Convenience Functions Available Again. The Low Battery warning will be stored in the IC and is viewable by scrolling to the Malfunctions/Messages menu. The second one is not stored.
Old Nov 22, 2008 | 10:48 AM
ruffrob's Avatar
Polar,that was the exact message I saw,and given the explanation about the battery not charged,and the fact I didn't leave my car unattended with the battery draining for that long (mid day to the next morning). Everything is okay,thanks to you guys for all your help.
Old Nov 22, 2008 | 03:30 PM
MercFiveHundred's Avatar
2014 E550; 2003 E500
Originally Posted by xr650rguy
'06 E500
I have an 03 E500 and i had similar problems. I changed the stalk switch myself (around 100-120 USD for the part) and it now works great. Only problem is i still have an SRS malfunction because you have to remove the steering wheel/airbag. I think it just needs a reset. Are you still under warranty? What went bad in my stalk switch is the wiring within it wasn't thick enough and it shorted/burnt out.
Old Nov 24, 2008 | 05:15 AM
ruffrob's Avatar
Hey,XR650,thanks for highjacking my thread....
Old Nov 26, 2008 | 09:29 AM
Benzo1999's Avatar
2003 E500 Sport, 1999 ML430 & Regal 402 Commodore
I got the power down message after leaving my lights on. I guess it's letting you know that you left something on and switched to conservation mode.
