Keyless go? Can you treat the car like it does not have keyless go?
Many people do not like things in their pockets, particularly when seated and belted. In the W211, thankfully, you can put the fob/key in the ignition just like a normal non Keyless Go key. But the Lexus system (and the GM system, and I belive the Infiniti/Nissan system) doesn't have that option. So the fob winds up in a door pocket, ashtray, console, or other storage cubby. Then, 10 to 40 years of car driving experience tells you that when you park your car, you turn the key off, and continuing to hold it in your hand, bring it with you when you leave the car. Not having the key in your hand when you turn off the car interrupts that established pattern of behavior, and makes it pretty likely that the fob will get left behind whevever you stashed it, leaving the car unlocked. And if you are a "car as appliance" Lexus type, driving a Lexus that is very quiet at idle, you might even leave it running.
Back to the MB W211 system which is the subject of the thread, again, I remain pleased they let us folks who dislike change have the option of pretending the car doesn't have keyless go.
I agree, I do like having both options - the keyhole if needed and the button if desired.
Based off that, they may still continue to have the keyhole for the base models, but I would assume Keyless-Go will still be an option for them to get more money from, and that it will be like the ML and eliminate the "standard" ignition.
There was a thread started a while back regarding the ENGINE START/STOP button getting to too hot in the summer heat and some people investigated retrofitting the ML type button to cover up the conventional keyhole so it would not be in direct sunlight.
Each door handle has a square black button on the outer edge of the handle. You press any of these buttons to lock the car. The inside of each handle has a rubber pad switch inside, facing the painted surface of the door, which when squeezed by your fingers when you pull on the handle sends a signal to the car if you have the smartkey in your pocket, to unlock the doors.
