Adding Active Cornering to Bi-Xenon
It can be done BUT will require a LOT More parts other than the Headlights
But my W211 Did Not have Xenon Headlights
Since the car has Xenon with level, the level sensor is there...
Active Headlights get the signal from the turning angle sensor
I Would say yes, But your car is a EARLY 03 W211 so you MIGHT need different sam units to support the optional headlights
Please Mail Steve @MBENZNL.com
Mark, anytime you want to send me one of those money trees, I'll PM you my address.
I think you've retrofitted every option except the external auxiliary cabin heater. When's Steve gonna do that one for ya?
Several left to do...
No Stand alone HeaterDesigno PLUS Alcantera/Leather Dash/console/door panels with matching Headliner/visors
)and mark still has a long way to go before his car can be called "fully optioned"
greetingz,
greetingz,
http://www.huntingtonbeachweather.co...ilyreport.aspx
greetingz,
Steve
Steve
I understand there could be a minor chance that the cluster was faulty and reported this malfunction but are you sure they did not change the head light unit (where a known issue exists, although usually repairable if the shop reads their papers and knows how to do it).
In any case, if you consider active cornering head lights a potential source for failures, shouldn't you then start considering if the car should have a radio, perhaps the engine could fail too...
Steve
Would really like to avoid spending $1000+ if I can. You said this is a known issue? As in MB knows about it and is taking care of folks that have it?
Steve
