E-Class (W211) 2003-2009
Old Jun 15, 2015, 04:08 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Diagnostics
Print Wikipost
Gas odor when tank is full
Old Mar 26, 2020 | 10:52 AM
  #51
e350forme's Avatar
fleet
Originally Posted by mtupower
My 04 e320 wagon stalls sometimes when braking and the interior smells of gas after it's filled up. ugh. the recall ended for 04 last july.
there is an easy to replace seal where the sender sits under the seat. the stalling may be unrelated.
Old Mar 26, 2020 | 11:06 AM
  #52
mtupower's Avatar
1984 300TD/2006 CLS55/04 E320 wagon/05 CDI crashed :(
So I pulled up the carpet and access port and found a bit of very old liquid around the sealing ring both inside and out of the housing. I cleaned it with paper towels and then found the sealing ring itself wasn't tight. Wasn't overly loose but it did spin about a 1/3 turn. Everything else looked fine on both sides. No cracks, nothing out of the ordinary. The passenger side was dusty dry. Hoping this solves any issues!
Old Mar 26, 2020 | 11:08 AM
  #53
mtupower's Avatar
tell me! thx
Old Mar 26, 2020 | 11:19 AM
  #54
kajtek1's Avatar
1922 Ford Model T / no OBD
Check codes. Loose seal on tank should trigger one.
Clear whatever computer might have in memory and check if stalling still happens.
Old May 16, 2020 | 03:44 PM
  #55
Rovel's Avatar
2007 E63 Amg
Why don't you guys get it fixed under the warranty? I got mine taken care of by the dealer.
Old May 16, 2020 | 11:34 PM
  #56
cetialpha5's Avatar
If you read the thread, he was past the 15 year warranty. It's only 15 years unlimited miles for the extended warranty on the fuel tank.
Old May 16, 2020 | 11:39 PM
  #57
Rovel's Avatar
2007 E63 Amg
There is a thread somewhere over here that one can submit for reimbursement. Does that apply to repairs occurring after 15 years have passed?
Old Jan 11, 2021 | 06:59 PM
  #58
39039's Avatar
W221 S550 4MATIC
I fixed it.
Old Aug 5, 2024 | 03:04 PM
  #59
MrWJB's Avatar
2014 CLS500 (NO 4MATIC)
2014 cls550, gas smell fixed
This is the fuel pump sender unit. It's located under the rear seat driver side.
Now you see the sending unit completely removed and the pull string they're waiting so that I can install the new one when I get it in 48 hours. If you have any questions please feel free to reach out to me.
As you can see this is the top of the sending unit and the cracks are abound. This must have been leaking for a while, but finally got to the point to where the gas smell could not be buried. Initially I did not want to do this, but the dealer wanted to charge me $2,300 for this fix.
Just to make things easier because I did not want to put my hand in the gas tank and try to fix it through the small hole I just attached the string on the disconnected hoses from the fuel pump so that I could pull the entire unit and the string out to the other side. When I replace the part I will just attach a string and pull it through the other side in the reverse order.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
