Alignment Service Bulletins??
I have had mine in twice and they cannot get it fixed. They acknowledge it needs to be corrected. They say it shows absolutely correct on the alignment machine. They switched wheels.
Do I remember that someone else had a similar problem and got it corrected? Was there an actual Service Bulletin on this? If so has anyone got a number or at least enough information to describe to the service advisor?
BTW...had the ticking noise..switched motor mounts and all is perfect in that department.
Ed
how many times is the alignment covered under warranty
Regardless of the crown in the road it does this.
Obviously less though when the crown is on the right.
Camber is the axis angle upon which the steering knuckle rotates, if both front wheels don't have a matching camber it may pull even if the alignment is perfect.
Does you car have Right Hand Drivers position?
If so I'm wondering if, since yours drifts left and those of us in the US all seem to have drift right, maybe the factory is overcompensating for the weight of the driver in setting the initial camber for the front end.
If so, they have done it to offset which side the driver sits on.
LHD would drift right RHD would drift left by default if this is true.
In Singapore, it is RHD. What you said could be true.
I am sending in the car when they have gotten the parts to replace a crack in the right hand signal lens on the wing mirror. The service center did mention that it was an alignment problem. Seem to be a common problem with the W211.
