- Mercedes-Benz E-Class: Warning Lights
Important information to help you understand your Mercedes-Benz
Red battery message ( Visit workshop)
Do not waste your time. You have two and only two good choices. 1. Go to the Mercedes Benz dealership, give them your VIN and buy the correct battery. 2. Buy the Interstate auxilliary battery mentioned above. (Interstate Cycle-Tron Plus 'factory activated' battery ready for installation. FAYTX14 MFG # M7RH4S)
As for the rear, primary battery, my cost at Mercedes was LESS than the cost for the Interstate battery.
Remember, you are driving a sophisticated, expensive automobile, not a corolla. Even if you bought it used for $15,000, you still need to service it like its a $50,000 car. Because it is. I save my money on the labor side of the repair and never skimp on parts.
So I would not consider an aftermarket battery "messin up" if it fits, has proper mounting,vents,post, and power as described above.
Besides I have so many other "high tech" stuff break on the MB why not just use items that meet the spec such as M1 0w40 Oil vs buying oil from MB.
Hell nearly my whole front suspension was made from a company in taiwan except for my upper control arms and they are giving me no problems 35,000 miles STRONG and the car feels tighter than a vigrin. I have Ebay Rotors and brake pads and my car stops on a dime with no noise or warping.
I seriously doubt that! To say that an independant supplier is charging more for a battery than any dealer?
Come on now. What do you take us for?
If you have the money to waste, go to the dealer and pay whateven amount they ask.
On the other hand, If you are like me and living on a 'fixed income', and understand basic mechanics
and electronics, do-it-yourself as I and many other here do and enjoy the savings.
Even were I a millionaire which I am far from being, I
would still do my own repairs when I am qualified.
Derrel
I never thought about ebay for suspension parts? Which parts did you buy? My ball joints went out around 70,000 miles and now at 117,000 I am expecting them to fail again.
The main company is called Lii Hau or something i forgot but they have their own website and look like a pretty legit company. I even posted a youtube video showing how tough the ball joints were when I got them.
I found a picture of this guy online...
Derrel[/QUOTE
My cost for the Mercedes Benz primary battery was just over $200.00 and the Interstate battery was $231.00. I get wholesale pricing at my dealer which saved me about $50.00. I did not have to waste any of my time doing research and hoping that a cheaper battery would work properly with the vehicle's own self-diagnostic systems. I would have bought the Interstate secondary battery had I known about it in advance. I didn't even know that the car had two batteries until after I replaced the trunk mounted battery. I stand by my decision to stick with dealer parts whenever practical.
That said, I just replaced the water pump, idler pulley, belt tensioner, and serpentine belt on my 2002 ML320 with high quality parts purchased from AutohausAZ. The only items I bought from the dealer was a thermostat gasket and 2 gallons of coolant. Perfect repair. Saved a lot of money. It depends on the situation and the complexity of the vehicle. The 2004 E500 has an overly complicated electrical system and if the car needed to go in for dealer service, dealers are notorious for blaming everything on aftermarket parts, especially electronics. I have no issues with using Interstate batteries and neither would the dealer. If running around to Walmart or Autozone and buying a battery that needs to be activated and charged is a good use of your time and money, then that's fine. To me, it's a waste of time and money, because my time is money.
Don't get me wrong. I will use a quality aftermarket part on my Mercedes Benz or BMW whenever appropriate, but not all the time. Nor will I ever modify my vehicle to accomadate an aftermarket part. A perfect part is perfect. If it isn't perfect, it's not worth it at any price.
I just hope you are not one of people that believes your insurance company when they tell you that aftermarket sheetmetal is just as good as the dealer part.
Have fun at my expense if that makes you happy, but to me your logic makes no sense. Neither does your math. I replaced OE batteries on a 2004 with OE batteries 7.5 years after production and never had a no start situation. Try that with your Walmart battery.
[Suggeted retail is $278 for the Interstate MTP-49/H8A!]
I would have bought the Interstate secondary battery had I known about it in advance. I didn't even know that the car had two batteries until after I replaced the trunk mounted battery. [Why? Did you not study this forum? There is one topic on that subject that is almost 300 posts long!
I know, you are too busy as time is money!]
[Not too wise IMHO]
That said, I just replaced the water pump, idler pulley, belt tensioner, and serpentine belt on my 2002 ML320 with high quality parts purchased from AutohausAZ. The only items I bought from the dealer was a thermostat gasket and 2 gallons of coolant. Perfect repair. Saved a lot of money. It depends on the situation and the complexity of the vehicle. The 2004 E500 has an overly complicated electrical system [How so?] and if the car needed to go in for dealer service, dealers are notorious for blaming everything on aftermarket parts, especially electronics.
I have no issues with using Interstate batteries and neither would the dealer. [Why is that? Cause they know that the Interstate battery is better than there own?]
If running around to Walmart or Autozone and buying a battery that needs to be activated and charged is a good use of your time and money, then that's fine. To me, it's a waste of time and money, because my time is money. [Do you happen to know who make the batteries for Walmart or Autozone?
[No need for that, as I drive carefully and have not ever had such a serious accident in over 60 years driving where any sheetmetal parts needed to be replaced.]
[Sez you. Look how many other posters agree with my way of thinking!]
So what? I got nine years out of the original Ford battery in my 2000 Ford Focus Kona model.
Ford had a good original battery supplier. Does that mean that the new battery the parts
department sells you today is of that same quality as the one made in early 2000?
Some of what you write tells me and others that you do not understand basic electronics.
Either a battery works or it does not. Either it is of the proper size physically or it is not.
Either it had the correct amperes hours, or it does not.
Well my friend, it appears that you have much more money than I do.
It also appears that you do not know who to contact and where to get good pricing!
As an example, I found that retail for the small up front battery was $131 right
off of the Interstate site, but my friend got it for me for only $66 plus tax.
I am sure he will be able to do the same thing for me when it comes time for me to replace the
large battery in the back, and I will not be paying anywheres near to over $200 as you did.
I do not have fun at anyones expense, but I do tend to point out faults when I see them, and for you
to say that the factory MBZ battery is better than anyone else makes is just plain ignorant!
Do you think that MBZ makes their own batteries?
Did you notice the name on the small battery when you replaced it? It was not German was it?
Made in Italy, not Germany.
MBZ has their batteries supplied to them by some large manufacturer.
Who of us are qualified to say which manufacturer produces the best battery?
It is not clear to me what you wound up paying for your factory MBZ battery.
Was it just over $200 after your wholesale pricing?
I have not felt the need to replace my main battery yet, but when I do, I will have my parts manager
friend check around for me and get me what he feels is the best deal and that is the one
I will use, and I will bet you, it will be far less than slightly over $200.
Recall that I paid only $66 plus tax for the small battery up front,
and I am sure it will be just fine, thank you.
Try pricing that one at your dealer even with your so-called discount and see how much it is?
The big battery for my CDI (the same as your E-500) is only $98.99 at Walmart if I recall correctly.
So less than half price of what your MBZ dealer charged you?
If you are so sold on using genuine MBZ parts, why did you use someone elses
parts when you did that water pump and related other installations?
Or did you get the MBZ parts costs from your discounting dealer and
find you could do better using an independent supplier?
No sir. You do it your way and waste money, but I will try to save money and do it my way.
At my age, I must try to hang on to what few dollars I get, and
throwing them at the dealer is not good thinking IMHO.
Of course, try to stay away from Chinese parts, but how do we
really know where some parts are made until we get them?
Carry on. You do it your way and waste money and myself
and others here will do it our way and save money.
Which way is the smarter way to go?
Derrel
Derrel[/QUOTE
Derrel
It is obvious from your remarks that you are not the first owner of your vehicle. You resent those that don't have to do it your way. I'm not sure why. I'm certain that when you buy your next Mercedes you will look for the best car you can afford and you'll try to find a one owner, dealer serviced vehicle. And why not. That's what I do to.
When it comes to taking care of his car I do the best that I can and save him money whenever I can. If it were my car, I would have spent more time on this forum and would have had been willing to drive around for a week or two to see if the red battery message would have cleared itself. He was not comfortable driving the car at all with the warning message illuminated. I replaced both batteries at the dealer on a Saturday and on Monday morning I was at the dealer to get the code cleared and make sure that the entire charging system and the battery control system was functioning properly. It was. By 10 AM that morning I was done and my father was happy with the outcome.
I would definately have purchased the secondary battery for $70 if I knew of someone that would sell it to me at that price. In the end the only thing that matters is that the car was repaired and my father was pleased that it was done quickly with minimal downtime. He bought the car new. He can afford to care for it properly. I wasn't thrilled with spending over $300 on batteries that Saturday, but he wasn't concerned. I also tried the recommended procedure to clear the code. It did not work for me. By the way, none of it was a waste of money. The dealer parts are the best. Period. They aren't the only good parts, but they are the reference standard. Always. I don't resent your trying to save money on your maintenance. If you are absolutely certain that the batteries you have selected will perform perfectly, then by all means use them. The wrong batteries can and will cause electronic faults in the E500. Just read the forum. Buying dealer parts is never a mistake. It is not a waste of money. It is more expensive. You always get what you pay for.
As for the comments that I don't understand that electronics or the principles behind the battery and charging system is rediculous. I install marine electronics and maintain my own vehicles and powerboat. Thirty five years experience has proven a couple things: cheap tools are cheap tools and cheap parts never save money. Save as much money on labor that you can, but don't buy cheap parts. They end up being too expensive in the long run.
I wonder how many people buying a new Mercedes Benz with money they have and money they have earned would agree with your logic? According to your logic, buying a new Mercedes Benz and having it serviced by the dealer is a waste of money. They must all be stupid fools, right?
As long as you are asking, my way is the smarter way to go. You apparently did not read my words carefully.
I never said that I do not use aftermarket parts on my vehicles.
The E500 is owned by my father. He purchased the car new and other than the maintenance services that I can provide such as brake service, brake fluid flushing, tune up related services, and non computer required mechanical repairs, the vehicle has been serviced exclusvely by the nearby Mercedes Benz dealer. Dealer service is expensive whether you own a Honda or a Mercedes.
[There are some others here who along with yours truly who most certainly do not agree with you.]
[I do not resent those who have money to burn; I do resent anyone who simply put wastes money!]
You should be concerned wasting your fathers money no matter how much he has. I figure that had you bought both batteries correctly, you'd have had them for well under $200 and you would have had better batteries.
Genuine MBZ batteries are not as good as the Interstate line.
BTW, how do you know that the rear battery needed replacing?
IF you troubled to read the long discussion on this topic, you would know that the problem is with the small inexpensive aux. battery, and not both batteries at the same time! Interstate guarantees their big battery for 85 months!
[Not so!]
[Why oh why do you mistakenly say that?]
[Not necessarily so!]
[Well it seems my friend as there are many here who agree with me and have so stated]
[You said it and many agree with that statement.
I am glad there are such people as I cannot afford one new any longer and even IF I could, I would not as the new ones are simply not the car the older models are. Especailly in the diesels. But don't get me going on the differences between mine and the new onse beginning with the 2007s.]
Quoting both yours and the message you want to quote is not at all necessary.
Being a younger person, I am surprised that you do not know how to do that correctly!
Regards,
Derrel
I then moved the car out of the garage and pulled over. Turned it off, entered the service menu and got the voltage display. Started the car, same warning, same conditions. Drove it home and noticed the voltage read anywhere from 10.9-12v WHILE driving even under load. However, about 2/3 of the way home, I noticed the voltage jump up to 13.9v and stay there, pegged. Giving it gas varied it to 14.0 but that was about all.
Car is a 2006 e500 4matic, original batteries to my knowledge, never had the alternator done and I don't believe the BCM was done nor the aux relay. Car ran fine the rest of the way home, started up later that night with no alarms and again this morning with no issue whatsoever. Any direction one of the vets can point me in? I'm just not the type of person to throw parts at a problem without proper diagnosis.
BTW I can create my own contest I have no plans to join another. :-)
Yeah that's what I had figured, I was probably going to replace just the little guy up front anyway, they're both original batteries to the car. I'll probably have the dealer run a VMI anyway to see if the BCM or regulator have been replaced as I've noticed the headlights/cluster dimming from time to time also, usually when the SBC pump kicks in.
Sounds like you are on the correct path.
Try replacing the little battery (the Fiamm) up front and see what happens then.
The fact that your car was able to be started several times tells you that
the monster battery in the rear is most likely still okay, at least for now.
After you remove and replace the smaller front battery, check those cells
for voltage and I think you will probably find at least one dead cell.
See what happens then, and IF you are still having problems, then proceed to the dealer.
Good luck!
Derrel
How do I test the alternator to see if that's the problem?
Seems unlikely that an only one year old aux. battery could go bad, but anything is possible.
The fact that the rear (hugh) battery is fully charged speaks well for the alternator wouldn't you agree?
If she gets the red light again, disconnect the aux battery and check if to see if it is fully charged.
That would be the simpliest and easiest plan of action IMHO.
I drove mine for several weeks with a bad aux. battery and nothing happened. Tell her not to worry.
As long as it starts, the altenator is doing its job keeping the main battery fully charged.
Derrel
Derrel
My causes for concern are that I don't believe the main battery has ever been replaced (bought it used as a lease return after 3 years). Could it also be possible that a relay or some other wiring is faulty? That's not something I'd be able to assess though.
Of course, it could be that relay, but you will know when you check out both batteries.
There should be a date on the larger battery telling you how old it is.
Please keep us posted.
Derrel
I load tested both batteries before starting the car again. It had been sitting since 8am. The main battery showed it was "healthy" (12V range) before and after starts. The auxiliary read "healthy" (also 12V range) cold but dropped to 10.2V under load. Is that considered weak? I left it on for about a minute and then the aux read in the "healthy" range under another load test. I don't believe I have a charging issue from this.
I turned the car on once for about 15 seconds and had the warning. The second start, where I left it on for about a minute, produced no warnings (car was not moved either time). The build date of the aux battery is 36 10 and was installed June of last year.
What do you gather from this?
90% = 12.62
80% = 12.50
70% = 12.37
60% = 12.24
50% = 12.10
40% = 11.96
30% = 11.81
20% = 11.66
10% = 11.51
[In other words, it was showing that it had 12 volts now, but it cannot 'hold' a full charge because of one cell failing.]
I don't believe I have a charging issue from this. [Agreed. You do not INMO.]
That is exactly how my original aux battery did for several weeks after I purchased my CDI used in December, 2011.
I would start it and drive to the mail box and shut if off, and a minute later,
when started, the message would be gone and stay that way all day long.
The problem was definitely the aux battery, as it had one completely dead cell.
When I removed it, that same 10.2 volt reading is exactly what I got. In other words, one dead cell!
You do know that each cell should have at least 2.1 volts plus by itself?
The fact that the 'new' aux battery is only showing a little over 10 volts
tells me that your problem is with that 'new' aux. battery.
It's hard to understand how a practically new aux. battery could fail, but it was not exactly new
(Build Date-Wise) when it was installed. Is there any guarantee with that battery?
In the past, I have seen brand new batteries be bad right off of the shelf.
I am of the opinion that there is a failure with the replaced aux. battery.
Hard to tell when you must simply throw parts at the problem. But it appears to me to be the aux. battery.
Good luck.
Derrel
