Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Mercedes-Benz E-Class: Warning Lights
Important information to help you understand your Mercedes-Benz
Red battery message ( Visit workshop)
#501
They were probably hurting themselves by not making the AGM aspects of the Eliminator Ultra clearer in their marketing. I'm impressed with how our friend esaldanha has negotiated the issues with his wagon in Canada, where this forum can be a little short on the kind of information that makes it so valuable ("go to this store and get this part number for this price", etc.), and is now enjoying his ride!
#502
For what it's worth in these very cold, battery-challenging times:
From now through 2/28/15, PEP BOYS is offering the BOSCH H8/Group 49 Platinum Series Battery for 35% off, if ordered online and picked up in the store. Use code SECRET35 at checkout. That makes the battery a little more than $130 plus tax. And there's also a rebate from Bosch.
That's one good deal for an excellent AGM battery for our cars.
#504
The SECRET35 buy-online-pick-up-in-store deal has been extended until 3/7. I was thinking about the AC/Delco Group 49 at Amazon for $145, but this is a better deal for the Bosch Platinum AGM H8/Group49 for just $130 when you input that code at checkout.
#505
I was planning on going for the diehard gold 14-bs agm since it supposedly is fully compatible...ie no bending brackets, no swapping out nuts or replacing them, until I read the reviews on this battery. out of 10 reviews 9 were 1 star. pretty poor. so now im looking for an aux battery that is threaded so I can use all the original bolts, etc. I have a local autozone but if im not mistaken, theCTX14-BSFP, you have to use some nut with it and that it isn't threaded.
I read on one of these posts that the interstate battery will fit my needs.
I just want to verify the model number of that interstate battery
earlier in the thread I saw Interstate CYTX 14-BS and later on someone named bigben swapped it with an interstate battery but he didn't specify the model. does anyone know if this particular interstate battery is threaded and is a straight swap out with no mods needed?
thanks
will
thanks
will
#506
thanks
will
thanks
will
#507
Use the Yuasa agm from Amazon mentioned above. Perfect fit. You use the nut from the bag that comes with the battery, which perfectly fits the Mercedes screw on the wire. It's super easy and it's a great battery. I used it and would do it again, although likely won't have to bc the Yuasa is top of the line. Ytx14-bs.
thanks for the reply, but that's what I want to avoid. I want to use the same bolts without any mods, or replacement parts and be done with it.
#508
For as long as it took you to agonize about this issue and type your question, you would be done with it.
But to each his own, I guess.
#509
I say this respectfully: that's just silly. It's a nut. It goes in the post. It's not a "mod". It's not a bolt or anything that requires changing anything about the MB setup. You ARE using the same bolts. There are no "replacement parts". It is JUST AS EASY. Heck, you are unhooking all sorts of stuff, pulling things out, making sure you connect things up to the correct polarity, etc. Unless you have some physical handicap that would preclude you from inserting a nut into a battery post, in which case you shouldn't be doing this in the first place, I wouldn't be concerned about this in the least.
#510
Exactly. The terminal post has a square hole on the side of it, and you just slide the nut in there. In my car, the leads (wires) for the battery are connected to a metal piece with a bolt (or screw) through it, and that bolt stays permanently attached to that metal piece, although it spins freely. You just put that bolt through the top of the terminal in the new battery (which terminal has a hole in it), the bolt goes through the nut, and you turn the bolt until it tightens the nut against the top of the battery terminal and forms a secure bond. It's just as easy as if the top of the battery terminal was threaded. Amazon.com: YUASA YTX14-BS Maintenance Free Battery: Automotive
thanks
#512
btw, how long did you charge your battery for? I just got it today, filled the acid and try to find in the directions how long I should charge it for. directions are a bit vague. I figure overnight @ 2 amps should be ok?
thanks
#513
I had a 2/6/10 amp automatic (i.e. turns off by itself) charger, and gave it an hour at the 6 amp setting.
Glad it came and you are almost in business!!
#514
Yeah, you can do 6 amps for one hour, or 1.5 amps for 5-10 hours. Do you have a float charger (i.e. one that turns off when the battery is full?). If so, you can leave it overnight. If you don't have one that has a green light to show you when it's full, or if it doesn't turn off when it's full, I would give it no more than 5 hours at your 2 amps. Better to err on the side of not frying it.
thanks
#515
If you want to let me know the brand and model, I can look it up for you. I have the specs on a lot of brands and models.
#516
all I can find on the charger is that its a sears. I cant find a model number. the good news is that it says automatic on/off charging system right on the front. so I guess I didn't have to worry. by the way I was wrong about it doing 2/6/10 amps. it says 2/10/60 start. this charger is fairly old. maybe 10+ years old.
thanks for your help
#517
#519
Battery visit workshop
I have some post that reference the fix for Battery visit workshop as replace auxillary battery. That was my solution for 2003 e320. However, it required a Star to reset the code.
Once code was reset, problem is solved.
#520
getting red warning visit workshop on dash
its a whole lot of guessing on here but the real problem CHECK BATTERY POWER RELAY OR BATTERY CONTROL MODULE HOPE THIS HELP The technician was working on a Mercedes. A red battery symbol with the message “Visit Workshop” was displayed in the message center of the instrument cluster. The battery and the alternator have been replaced with no results.
When the technician called Identifix, I asked if testing had been performed on the Battery Control Module (BCM) with a factory-compatible scan tool, and if the front battery had been tested with an electronic battery tester. The reply: “There’s a battery under the hood? Where is it??”
Starting in model year 2003, Mercedes came out with a new E-class model with the Mercedes chassis designation 211. One of the new features of the 211 is the Dual Battery System. A main systems battery is in the trunk of the car and an auxiliary battery is located under the hood, underneath the cabin filter at the right rear corner of the engine compartment.
The Dual Battery system uses a BCM, located next to the systems battery, that is in charge of the usage and the diagnostics of the auxiliary battery. It also monitors the voltage of the systems battery along with the amount of charging system output. The BCM uses the information to perform tasks in relation to both batteries. During normal operation, the BCM will perform a battery voltage test of the auxiliary battery. Depending on this voltage, the BCM can operate what is called the auxiliary battery relay. When this relay is energized by the BCM, the auxiliary battery becomes connected to the vehicle’s main battery. This, in turn, allows the charging of the auxiliary battery until the BCM turns off the battery relay. After that, the auxiliary battery will be disconnected from the vehicle. The BCM will then monitor the battery voltage and charge rate of the systems battery.
During a low voltage condition of the systems battery, the BCM is capable of prioritizing consumer shutoff operations in stages, in order to help the systems battery regain its voltage more quickly. During “stage 1” of shutoff, a message displayed on the instrument cluster states that the system is in consumer shutoff operation, and items such as the rear window defroster and heated seats will stop functioning. If the BCM determines that this is not enough to restore correct voltage of the systems battery, the BCM will then perform “stage 2” of shutoff. At this point, the driver may notice that any components plugged into their accessory outlets will stop operating, along with reduced blower motor speed operation.
Next is the “emergency mode.” For example, if the alternator fails to operate or if the systems battery voltage becomes too low for the operation of the vehicle’s electrical system, the battery control module will not only activate “stage 2” but also activate the auxiliary battery relay to connect the auxiliary battery to the vehicle’s electrical system.
Why add all these extra functions on a car that works just fine with one battery? One of the main reasons is that the Sensotronic Brake Control (SBC) brake system on the 211 series vehicles is part electronic and part hydraulic. This brake system has no substantial connection between the brake master cylinder and the rest of the brake system. The SBC system uses an electrical pump that will pressurize the brake system for operation. If there is an electrical failure of the vehicle’s charging system or an accident which damages the systems battery or alternator, the use of an auxiliary battery is needed to help maintain proper brake operation, and bring the vehicle to a safe assisted stop.
How do you know what to look for? Testing of the Dual Battery System requires the correct tools. The BCM operates on the vehicle’s data bus giving out valuable data that can be read with your scan tool, such as alternator charging current. It also stores fault codes along with maintaining a memory of consumer shutoffs. Not only is this system used in the 211 chassis but also in the 219 chassis, also known as the CLS class. The wiring diagram on the next page shows the BCM and its components.
In this Hotline subscriber’s case, a voltage test of the auxiliary battery found it to only have a rest voltage of 10 volts. Testing it with an electronic battery tester showed it to be faulty, so the battery was replaced. After the next key cycle, there were no more warning messages in the instrument cluster.
So the next time a 211 E-class comes in the door with a red light on the instrument cluster, be sure to check the other battery under the hood.
#521
Volts and amps are two different things.
It is possible to have 14.2 volts with a diode pack bad. However if your alternator is a 90 amp and 1 diode pack is bad it will only be putting out 60 amps which means it will take longer to charge the battery. On short trips this won't be enough to keep the battery charged but on longer drives it might be able to keep up.
Car was fine, had to change all freeze plugs. Inspected alternator and brushes were at the end. New ones fitted. I got the red battery light from then. Everyone insisted on the regulator. It seemed almost impossible to be the regulator, i didnt even moved it but, i fitted a new one. Still red light. Will change the belt and tensioner tomorrow, its not in good shape. Lets see how it goes.
#522
Battery help
I have confirmed my aux bat needs replacing as it only has 10.4 volts. I load tested the main bat (in trunk) and it full load test ok. I have also run my (US made) diagnostic on the charging system and it is fully functional with no issues. So I really need only the aux bat. Where is the best place to buy the aux batt. I called my supplier today and the best I can find on $$ is $140 for the aux battery. Somehow this seems to have a high MB tax applied. I would expect this to be around $100? Any help here.
The batteries only differ in capacity and shape. They degrade over time and use just like the starter (Main) battery. The best batteries (as tested by Consumer Reports) are fresh ones. So the more volume that the supplier does, the better the battery the consumer will get. A Walmart fresh battery can outperform whatever a stale Mercedes battery sitting the shelf for a year can offer.
So why does Mercedes even offer a battery?
Why not simply list the common name for the battery on the case? On the battery compartment? In the service manual?
These are a philosophical questions for Mercedes.
For the W211 owner, take a look at the common;
14-BS Battery replacment (12V 14Ah Sealed) Maintenance Free Battery.
#523
You absolutely want an AGM battery in there, although it will "work" with a regular battery. But given that it's right under the air filter/intake, you're better off with an AGM battery, which isn't going to vent gas.)
Best deals:
https://shop.advanceautoparts.com/p/...erm=14+battery (reasonable if you order online and pick up in store, taking advantage of the 25 percent off)
Best deals:
https://www.amazon.com/YUASA-YTX14-BS-Maintenance-Free-Battery/dp/B000WJX4BQ/ref=sr_1_3?ie=UTF8&qid=1507399463&sr=8-3&keywords=ytx14-bs
(The YUASA is probably also the hands-down best battery, but if you buy it from Amazon, make sure it's "sold by and shipped from" Amazon, not some Marketplace seller)https://shop.advanceautoparts.com/p/...erm=14+battery (reasonable if you order online and pick up in store, taking advantage of the 25 percent off)
#524
Thank you part ordered!
Anyone have any idea how long for delivery?
I have done some research on a generic replacement. Today I went to a autozone and they had a direct fit/spec bat but it was acid version not the AGM. I tried to get the clerk but service as usual with young lady clerk and young guy customer.
So for the record.
The factory part is mfg by FIAMM
They have at their website a direct replacement bat but the terminals are slightly different. Down side is not easily available in US.
The best change was for a
WESTCO 12B-4 in the AGM version. But you must have the square top post for both vertical and horizontal mount. Many will only have the horizontal post.
Second option is DELCO GTX 14-BS but no one local had this one.
Walmart has one the size ES12BS and but don't know if it is gell cell (agm) or lead acid.
Didn't have time to get to Walmart with all the returns going on today.
So I do believe there is a generic that will fit at a lower cost. But for the $total $115.74 delivered to the door with exact part number it was no longer economical to spend my time looking. Only down side is I have to wait for delvery and wanted to install it today. (Taking a 1000 mile trip next 10 days so hope the order arrives)
Interesting the procedure for installing the aux bat.
1) It requires disconnect main bat in trunk
2) Then replace aux.
3) Follow specific reconnect procedure for install main bat or possible damage to bat relay
So I was a bit suprised that the main bat can't just be reconnected after being disconnected. But then ocassionally I do learn something new. Happy New Year to all and be safe. vettdvr
So for the record.
I ,tried to replace the auxiliary battery, didn't pay attention, and connect the wire wrong and made a short,
now I get the message that the aux,battery fuse or relay does not open,what could be, and where is the fuse or relay,located?
please let me know ,thank you
#525
1973 450 SL and 1998 SL 500, 560SL, 2013 SL550 Edition 1
Reset computer to clear error messages
I had both my batteries replaced in my 2005 SL500 and the red battery and visit workshop error messages still appear. Anyone know how to clear?
