head unit removal on my w211 e320 ??????
2003 w211 e320
i cant find any info on how to remove the headunit from my 2003 e320. i took the center console off already but cant seem to find where i need to insert the removal tools. please hit me bak asap i have everything i need to swap with double din pioneer navi but this is the only thing holding me bak and im going crazy lol please help pics with details would help alot
First, are you sure you have a W211 and not a US MY 2003 W210 (sorry for a basic question).
You would not need any radio removal tools on a W211. And you should find multiple posts explaining how this is done. Perhaps an example:
https://mbworld.org/forums/1353749-post2.html
2003 w211 e320
lol
well i only bought the tools because evryone was like oh u need the tools to remove it but i figured out i didnt cuz it didnt have anywere to go so i did loosen the screws but i pull and pull and nothing by the way thanx for the reply oh and the w210 is the one before mine im sure i have a w211
2005 E500, 2011 ML350
1. Pull up from front of shifter bezel and pop off.
2. Pop out ashtray (unplug cig lighter)
3. Remove (2) t20 torx screws from UCP, unplug 2 or 3 plugs on bottom, slide out (shifter will need to be in gear)
4. Loosen (2) t20 torx beneath radio, radio will now slide out.
2003 w211 e320
thanx guys everything looks awesome the only small detail i will add to it is give the screws a little push up isnt much but its what let me pull it out and once again thanx
2003 E320
post pics
Hey Im interested in Updating my sound system can you post pics of yours to see how it looks. I was thinking of finding a used command system at a junk yard. but if I can change it that will be better. does it sound the same?
2003 w211 e320
Radio changed
Bro i have totally changed the sound in the vehiclei installed a pioneer d3 at that point in time then change all the interior speakers to pioneer components nd shortyly after that amplified the whole thing plus i added 2 15s cvx with a 3000w mono block power acoustic and a 1200w 4 channel power acoustic plus added an extra battery in the trunk> the only set bak is that u have to deal with visit workshop with battery symbol when u first start the car. but i have had the car like this for @ years now and had no electrical problems
