W211 Biggest Complaint?
lol .. I'm only forty and sound old !!!! As for the gas tank being to big .. well that doesn't really make much sense .. you're going to use it sooner or later!
. It's a little humorous like the big 85mph speedometer in the Grand National back in the 80's and a bar-graph tach and boost gauge.The ones in my W123 and W201 still keeps perfect time!
Dislikes...
Electronically limited top speed of 130ish MPH. Anyone know how to get around that??? Good for Interstate driving I suppose but I drive the Autobahn to work everyday. My 94 BMW 750 topped out at 165 w/o mods.
60/40 rear seat issue:
In my 09 E350 when I release the passenger side rear seat (40) the front seat moves forward and can't be adjusted to the rear leaving 4-8 inch gap between the seats making it VERY uncomfortable for my fiance. I don't know if this is normal or not but it is quite the issue! Anybody else have this problem?
Ipod in the glove box. Really, this is just a pet peeve because 95% of the time I forget it is in the car...out of site/out of mind.
The passenger side seat will refuse to move back beyond a preset point when the seat is released, however the driver seat will move back and collide with the folded rear seat. I have renormalized them and they still do the same thing.
Dislikes...
Limited top speed 130 mph? Maybe the Winter Tyre speed limit is activated?
- Sunglass holder is too small. I use it now to hold a pack of Kleenex (pocket pack) which fits perfectly.
- Aux input is in the glove compartment. No good way to plug something in without leaving it open (I've modified this on mine).
- Cigarette lighter is in a bad spot right behind the shifter. If you have to plug something big into it, you might have to unplug it in order to shift into park (or you may have to shift out of park to unplug it). A power source in the armrest would be nice.
- Cup holder too close to the shifter.
- Extremely hard to retrieve items which fall between the seat and
the armrest. - Center armrest is poorly designed when it comes to comfort.
The only major problem I've had is with the HVAC which periodically quits for no known reason (normally when I need it the most). I know there is something about this which I will research before my next service.
