E-Class (W211) 2003-2009
Low beam problem
Old Jan 2, 2009 | 05:10 PM
Jazza1's Avatar
e320 cdi -05
Low beam problem
When I start the engine, 1 out of 3 times the left low beam won´t lift up to the right level so it will only light up about 15 meters in front of the car. The right low beam is always at the right level. It wont get down when I turn the engine off and when I start, it is directly in the right position.
Anyone who knows about this problem and can tell me what to do to fix it?
Regards from Ronny in a very cold place up in the north part of Sweden,
-17 C now in the evening.
Old Jan 13, 2009 | 05:55 PM
mcleantmw's Avatar
2003 E500 Benz & 2015 BMW M235ix
Your description of the problem isn't clear about "left low beam won't "lift" up to the right level"? Perhaps the bulb recepticle has dislodged from the holder. You need to unscrew the coolant tank to move it aside so you can better access the headlight fixture. It has a rubber cover which unscrews and then you can see if the headlight bulb recepticle is properly anchored. Might be best to replace the bulb while you are at it. The bulb receptible is turned counter clockwise to remove it and then you can pull the old bulb out and insert an new one........don't touch the glass bulb itself........dirt or oil from hands can shorten the life of these head light bulbs.
Old Jan 13, 2009 | 06:18 PM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
I assume you are referring to the Xenon auto-level testing procedure at startup?
Old Jan 14, 2009 | 04:06 AM
Jazza1's Avatar
e320 cdi -05
Yes, that´s right. When I start the engine the left one works from time to time and the right one is always in the "up" position. I think there must be something wrong with the autolevel system.
Anyone who have any suggestion what to do to fix this or must I take my car to the local dealer to have it repaired?
