E-Class (W211) 2003-2009
Resetting the command APS W11
Old Feb 20, 2009 | 08:06 PM
method's Avatar
2003 E55 W211
I was in the car the other day playing around in the engineering menu (getting the display to show AMG instead of the mercedes logo on startup), after about half an hour of driving just listening to the radio, the whole command APS unit turned itself off and back on. None of the right hand buttons work except for DVD which now shows a message saying 'no satellite radio' when you press it. You can't get into the service menu or the Map, it just doesn't do anything when you press them. Any ideas on how to completely reset the command aps? This is in an E55 w211.
Paul.
Old Feb 20, 2009 | 11:27 PM
konigstiger's Avatar
'71 Pinto
Try this:
- Turn ignition on and power ON the head unit
- Press and hold the key combination 5+3+7 in this sequence for about 8 seconds to access variants menu
- Scroll up or down and select correct head unit variant, press OK to confirm
- Press the “Keybrd” soft key for the list of possible keyboard types
- Scroll up or down and select the correct head unit Keyboard
- Upon correcting the variant and keyboard settings, turn ignition off and ensure MOST and CAN asleep
- Turn ignition ON and check functionality of all keys using different applications
Old Feb 21, 2009 | 12:42 PM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
There is no way that I am aware of to "reset" the COMAND, but follow the instructions above to hopefully get it working again. It sounds like you have changed the Keyboard variant to something invalid.
Old Mar 11, 2013 | 10:56 PM
AllHailBenz's Avatar
2008 E350 4MATIC
I have a 2008 E350 Sport 4MATIC and I did the same thing but the outcome of mine was that the whole screen is blank after start up... so trying to revert back to original setting are impossible.... Do you guys have any solutions?
