E-Class (W211) 2003-2009
Top speed in each gear for 7 speed
Old Apr 1, 2009 | 01:10 PM
MBE550's Avatar
2014 E350, 2015 ML350, 2017 X5
Does anyone have info on this?
I couldn't find it any where.
Not that important for 5 - 7, but will be useful for 1 - 4 when using manual mode.
Old Apr 1, 2009 | 03:24 PM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
Place it in "1" and drive off and note the speeds. It will shift automatically at redline.
Old Apr 1, 2009 | 09:00 PM
Green E-300 DT's Avatar
Late Built 2005 W-211 E-320 CDI
Talking Figure it for Yourself . .
Does anyone have info on this? I couldn't find it any where.
Gear ratios for the 722.9 tranny are as follows:
4.377
2.859
1.921
1.368
1.00
0.82
0.728
Now all you need is the rear-end ratio and the number or revs per mile for your rear tires.
Get the tire revs per mile for your tire from the Tirerack site.
i e . . .
Fourth gear is 1.368 times 2.65 or whatever (?) your rear-end ratio is times
811 (225/55-16s) and we get 2940 revs per mile same as 60 mph
or 49 revs per one mile per hour equals 82 mph at 4000 rpm.
Simple no? Crawl under the back and read the rear-end ratio off the differential case.
While I'm at it, the gear ratios for the 722.6 are:
3.59
2.19
1.41
1.00
0.83
We see that the seven speed has two overdrives while the five speed has only one.
Advantage . . seven speed for crusing with that extra 10 percent overdrive.
Also the lower first gear.
Who says you cannot have your cake and eat it too?
DHG
Old Apr 2, 2009 | 12:10 AM
Polar Bear's Avatar
4.377
2.859
1.921
1.368
1.00
0.82
0.728
i e . . .
3.59
2.19
1.41
1.00
0.83
DHG
The "." ".." "..." on the speedometer sure made it easier on the older models!
